swordz60
Newbie level 6
Hi guys,
I'm currently working on a project involving 2 arduinos + 2 LCD screens + 2 GPS modules + 2 nRF24l01 modules. The idea is to create a warning system for trains. It's based on the speed of the locomotive and the speed of the last wagon. The point of that is knowing whether any of the wagons got decoupled (I know that this doesn't happen often, but I work for a railway company and it seemed like an original project for my bachelor's thesis).
I've got both arduinos up and running (they output speed, coordinates, visible satellites on the LCDs), but i can't seem to figure out how to transmit GPS data (in this case speed) from one arduino to the other via the nRF24l01+. I have succeeded flashing an LED and transmitting a text message so far.
TL;DR: How do I transfer real time data from one arduino to another using nRF24l01+?
I'd greatly appreciate your input and I'm sorry if I missed a post on a similar subject.
I'm a newbie in C# language, just a warning.
TRANSMITTER:
RECEIVER:
P.S. I use 2 LCDs for testing purposes, after the project is complete, there will be only 1 LCD left (the 20x4 one). I will also add some other functions later (comparation of the speeds, a buzzer to warn about the difference in speeds etc.)
TRANSMITTER:
Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 #include <SoftwareSerial.h> #include <TinyGPS.h> #include <LiquidCrystal.h> #include <SPI.h> #include <nRF24L01.h> #include <RF24.h> int repeat = 0; LiquidCrystal lcd(7, 6, 5, 4, 3, 2); // Address used for the 16x2 LCD RF24 radio(9, 10); // 9 - CE, 10 - CSN const byte rxAddr[6] = "12345"; TinyGPS gps; SoftwareSerial ss(1, 0); // Define as software serial mounted as tx and rx void setup() { ss.begin(9600); // Serial communication at baud rate 9600 GPS to MCU lcd.begin(16,2); radio.begin(); radio.setRetries(20, 10); radio.openWritingPipe(rxAddr); radio.stopListening(); for (int count=0; count <= 5; count++) { lcd.setCursor(0,0); lcd.print("Starting..."); delay(800); lcd.clear(); delay(800); } lcd.setCursor(0,0); lcd.print("Starting GPS.."); lcd.setCursor(0,1); lcd.print("----------------"); delay(10000); lcd.clear(); } void loop() { bool data = false; unsigned long chars; unsigned short sentences, failed; // One second we parse GPS data and report some key values for (unsigned long start = millis(); millis() - start < 1000;) { while (ss.available()) { char c = ss.read(); if (gps.encode(c)) data = true; } } if (data) { float flat, flon, speed; unsigned long age; gps.f_get_position(&flat, &flon, &age); if (repeat < 2) { lcd.setCursor(0,0); lcd.print("Coordinates:"); lcd.setCursor(0,1); lcd.print(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 4); lcd.setCursor(7,1); lcd.print(", "); lcd.setCursor(9,1); lcd.print(flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 4); delay(5000); lcd.clear(); repeat++; } lcd.setCursor(0,0); lcd.print("Speed: "); lcd.setCursor(6,0); lcd.print(gps.f_speed_kmph() == TinyGPS::GPS_INVALID_F_SPEED ? 0 : gps.f_speed_kmph(), 1); lcd.setCursor(12,0); lcd.print("km/h"); lcd.setCursor(0,1); lcd.print("Satellites: "); lcd.setCursor(11,1); lcd.print(gps.satellites() == TinyGPS::GPS_INVALID_SATELLITES ? 0 : gps.satellites()); if (radio.available()) { char rad_spd = (gps.f_speed_kmph() == TinyGPS::GPS_INVALID_F_SPEED ? 0 : gps.f_speed_kmph(), 1); char rad_sats = gps.satellites() == TinyGPS::GPS_INVALID_SATELLITES ? 0 : gps.satellites(); radio.write(&rad_spd, sizeof(rad_spd)); radio.write(&rad_sats, sizeof(rad_sats)); } if (repeat < 2) { delay(2000); lcd.clear(); repeat++; } } else { gps.stats(&chars, &sentences, &failed); lcd.setCursor(0,0); lcd.print("Chars: "); lcd.setCursor(7,0); lcd.print(chars); lcd.setCursor(0,1); lcd.print("Sentences: "); lcd.setCursor(11,1); lcd.print(sentences); delay(1000); lcd.clear(); } }
RECEIVER:
Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 #include <SoftwareSerial.h> #include <TinyGPS.h> #include <Wire.h> #include <LiquidCrystal_I2C.h> #include <SPI.h> #include <nRF24L01.h> #include <RF24.h> int repeat = 0; LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Address used for the 20x4 LCD RF24 radio(9, 10); // 9 - CE, 10 - CSN const byte rxAddr[6] = "12345"; TinyGPS gps; SoftwareSerial ss(1, 0); // Define as software serial mounted as tx and rx void setup() { ss.begin(9600); // Serial communication at baud rate 9600 GPS to MCU lcd.begin(20,4); radio.begin(); radio.openReadingPipe(0, rxAddr); radio.startListening(); for (int count=0; count <= 5; count++) { lcd.setCursor(0,0); lcd.print("Starting..."); delay(800); lcd.clear(); delay(800); } lcd.setCursor(0,0); lcd.print("Starting GPS.."); lcd.setCursor(0,1); lcd.print("----------------"); delay(10000); lcd.clear(); } void loop() { bool data = false; unsigned long chars; unsigned short sentences, failed; for (unsigned long start = millis(); millis() - start < 1000;) { while (ss.available()) { char c = ss.read(); if (gps.encode(c)) data = true; } } if (data) { float flat, flon, speed; unsigned long age; gps.f_get_position(&flat, &flon, &age); if (repeat < 2) { lcd.setCursor(0,0); lcd.print("Coordinates:"); lcd.setCursor(0,1); lcd.print(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 4); lcd.setCursor(7,1); lcd.print(", "); lcd.setCursor(9,1); lcd.print(flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 4); delay(5000); lcd.clear(); repeat++; } lcd.setCursor(0,0); lcd.print("Speed: "); lcd.setCursor(6,0); lcd.print(gps.f_speed_kmph() == TinyGPS::GPS_INVALID_F_SPEED ? 0 : gps.f_speed_kmph(), 1); lcd.setCursor(12,0); lcd.print("km/h"); lcd.setCursor(0,1); lcd.print("Satellites: "); lcd.setCursor(11,1); lcd.print(gps.satellites() == TinyGPS::GPS_INVALID_SATELLITES ? 0 : gps.satellites()); if (radio.available()) char rad_spd[32] = {0}; char rad_sats[32] = {0}; radio.read(&rad_spd, sizeof(rad_spd)); //radio.read(&rad_sats, sizeof(rad_sats)); lcd.setCursor(0,2); lcd.print(rad_spd); //lcd.setCursor(0,3); //lcd.print(rad_sats); } if (repeat < 2) { delay(2000); lcd.clear(); repeat++; } } else { gps.stats(&chars, &sentences, &failed); lcd.setCursor(0,0); lcd.print("Chars: "); lcd.setCursor(7,0); lcd.print(chars); lcd.setCursor(0,1); lcd.print("Sentences: "); lcd.setCursor(11,1); lcd.print(sentences); delay(1000); lcd.clear(); } }
