[SOLVED] Mytech LCD Controller with Virtex 4 MB (Avnet) Board
ravics
Shangri-la
LCD Controller 8-bit interface vhdl code required for Avnet (Memec) Virtex-4 SX board.
LCD is of Mytech Corp.
Problem with enable timing
The enable signal should be high & low according to the timing ONCE when valid data comes/changes. But my enable is changing multiple times during the same data.
How can I write the logic so that the enable process is NOT repeated for valid data more than once? For subsequent valid data Enable should again be high & low once.
