Modelsim error Identifier "BUFG" does not identify a component declaration
hithesh123
Full Member level 6
lax
I compiled unisim libraries in ISE 13.2 and then imported them to ModelsimPE.
I also imported simprim and unimacro.
I still get the same error. Error and library screenshot attached.
Modelsim version is Modelsim PE student version 10.0c
Re: Modelsim error Identifier "BUFG" does not identify a component declaration
you either havent put the component in your design file or imported the components package.
What exactly is the components package?
often these libraries have a package in them that contains all of the component declarations so you do not have to copy them into your code.
How do I check if the libraries have the package containing the component declarations.
I checked unisim and it does have pkg declaration files. See screen shot.
Never mind. The library unisim and use unisim lines were commented out. Thanks to you I checked the vhd file.
