Look for library xbee for proteus
fiberManMada
Newbie level 6
Newbie level 6
Anyone have library isis for xbee? Help me please
The Digi XBee module is a transparent device and can be simulated by a hardwired serial connection between the devices. The technique can also be used when developing in actual hardware. After communication has been established with the hardwired serial connection and the overall design proven, the hardwired serial connection can be replaced with the XBee models.
There are no XBee models available for Proteus.
BigDog
Thanks for your reply. I m going to try your help.
But just few questions
what do you mean by "hardwired serial connection". Is it a component which exist in proteus?
This is the link that i found on the internet which use the block xbee in proteus :
In this article, they use a block of xbee with proteus. What i don't understand is, where did they find this block xbee? That's why i posted my question. May be someone can explain me if it is possible to build this or to have the library.
Thanks in advance
