George_P
Member level 2
scl05u datasheet
Hello,
Leonardo Spectrum synthesizer has a ASIC library named scl05u. After
synthesizing a design with this library I get a technology schematic
with primitive block named: AO2L0, OAI5R0, NR2R0 etc.
I understand these are all complex gates (AND-OR-Invert, Or-AND-
Invert, etc.) but I cannot find a datasheet or a vhdl/verilog code
describing their exact function and IOs connections. The "scl05u.vhd" source code I find in the installation directory of Leonardo does not include/describe these primitives.
Does anyone know if there is such a datasheet or source-code
describing these cells or simply understand what their function is?
An example of the synthesis results about cell/primitives usage:
Cell Library References Total Area
AN2T0 scl05u 1 x 5 5 gates
AO2L0 scl05u 1 x 8 8 gates
AO3I0 scl05u 1 x 8 8 gates
NR2R0 scl05u 1 x 5 5 gates
OAI5R0 scl05u 1 x 11 11 gates
Thank you in advance.
Giorgos P.
Hello,
Giorgos P.
