dipin
Full Member level 4
hi,
i am using JTAG UART fro quartus qsys system to print some values from fpga to nios 2 terminal. the register (32 bit) inside fpga updating at a rate of 10khz,and i am using a clock of 50 mhz to qsys system(to jtag uart). problem is printing every 4th values, in between 3 values are missing .i believe that its the problem of max through put of jtag uart.is there any way i can print all the values, ie did jtag uart can output a 32 bit register at 10khz ?
i am using cyclone 5 soc kit
thanks and regards
thanks and regards
