mhtplsh
Full Member level 3
We have P4BWA mother board. we recently bought it.
http://www.commell.com.tw/product/SBC/P4BWA.HTM
We have one ISA slot card previously working with windows 98.
The software with it is 32 bit.
one chinese site says it works with windows xp.
http://www.nju520.com/bbs/dv_rss.asp?s=xhtml&boardid=9&id=10461&page=1
注意:因为原DAAS32不支持WindowsXP,如果在Windows XP下运行DAAS32,请用Windows98兼容模式。
The software works ok but the card is not recognized.
we think this card is not PNP.
So it has to be set manually.
The manual says :
The default setting in ISA slot card is 358h-35Fh
Address of Converter
Board Selects the address range of the DAASâ32 converter
board. The normal setting is address 358h-35Fh. If this
setting leads to address conflicts with other boards the
range can be changed by setting jumpers on the converter
board. If the jumper setting does not correspond with the
setting under this menu heading, the error message "No
answer from converter board..."appears.
The following address ranges are possible:
· 1D8h - 1DFh, Jumper setting: J1 . . J8 = 0 0 0 1 1 0 1 0
· 2D8h - 2DFh, Jumper setting: J1 . . J8 = 0 0 1 1 0 0 1 0
· 320h - 327h, Jumper setting: J1 . . J8 = 1 1 0 0 0 1 1 1
· 350h - 357h, Jumper setting: J1 . . J8 = 1 0 0 1 0 0 1 1
· 358h - 35Fh, Jumper setting: J1 . . J8 = 1 0 0 1 0 0 1 0
How to get this card configured?
waiting for help/guidance in the matter,
The manual says :
