In which layer to put a hole
daviddlc
Full Member level 5
USA
I'm doing my own part, but I don't know which layer to use to put a hole.
Please help me out with this issue.
Please consider is on the library part.
Added after 27 minutes:
mmm I see that this went to a different part of the forum.
Anyway, the question was for Eagle.
Normally a drill for pad goes through all the layers while a drill for via may or may not go through all the layers.
In Eagle if you want to place a pad, it will be on layer 17 (can be done only in library editor). On PCB layout, a pad will be placed on layer 18 (Vias).
    daviddlc
