Ideal op amp (current to voltage converter + inverting)
naspek
Member level 1
Hey there.. need helps here..
The question is..
Derive an expression relating the output voltage, Vo to the input current, Iin.
i try to derive it.. but..
got problem with RL
V1 = -IinRf
Vo =- R2/R1(-IinRf) how to include Rl in my derivation?
Everything is correct.
If A2 is an (ideal) opamp with (nearly) zero output impedance, RL has no influence on the output voltage.
    naspek
If A2 is an (ideal) opamp with (nearly) zero output impedance, RL has no influence on the output voltage.[/quote]
Yeay!!! Thanks!!
