pozzari
Junior Member level 1
Timed Battery Cutout
I have a circuit with hysteresys using lm358
The circuits cuts the led when the battery goes below 11.5 volts and reconnects when the battery goes above 12.3 volts
This circuit goes on motorcycles, so when the motorcycle is starting-up the battery drops to about 10 volts and my circuit cut the load until the engine is running.
I need a timed circuit to delay the cut for about 10 seconds, just cut the load if the battery is below 11.5 volts for 10 seconds or more.
Be careful with current of the circuit, because the circuit can´t consume much power when cutted.
The schematic is attached
Thanks for all help and sorry my bad english.
