How to use the spi interface with custom ip
abhishek7
Newbie level 3
Newbie level 3
how to use spi interface with custom ip
Hi I have a custom ip with GPIO port and i have to interface this gpio with SPI interface,means which ever data is in flash is to be sent to custom ip through spi interface,the whole system is to be build on zc702 how this can be done can anyone help me out
regards
abhishek
Re: how to use spi interface with custom ip
How do you know when the flash has valid data?
Is the flash directly connected via SPI to this IP or via a master (in this case the flash is also a SPI slave)?
The custom IP with an SPI i/f can act as SPI slave device, but who is the SPI master?
You need to provide more details.
it is better to write SPI code yourself.
Your question is how to drive SPI flash?
you have to be more clear
