Hello all, I would like to ask you how to protect a circuit consists of microcontroller and RF modules (which need 3V and mA values) from a 1500V DC input connected to voltage divider.
Example is below and you can see that I do not need an over current protection:
I think the resistors will not be heated as current through them is in uA (max mA). I did not know much about protection, however I think of some keywords as zener diode and fuse.
Also, will there be a problem in connectors of the 1500V due to high voltage? Will I need a physical component to control it?
