Help me design a frequency multiplier
shanmei
Advanced Member level 1
USA
hi,
how to design a frequency multiplier, I donot refer to pll, but a simple circuit like frequency divier which is made by DFF. Anyone has ideas?
Thanks
frequency multiplier ic
i don't get u r Question completely!!
anyway if u r looking for simple multiplier, like simple divider using DFF
U can use Class C amplifier, with tank tuned to multiples of your input.
Hope this helps. If u find any other way let me know!!
Thanks,
circuit frequency multiplier
With your input frequency you could synchronize an oscillator tuned to the required output frequency.
frequency multipliers ic
shanmei said:
how to design a frequency multiplier ... Anyone has ideas?
Thanks
If your input frequency is a triangle or square wave, it owns harmonics. With a bandpass, select the required frequency (it will be a sinus), and amplify (& limit) it, if necessary.
frequency multiplier for a square wave
I think what you mean is a Delay Locked Loop Right. Search for it on google.
fequency multiplier
AFAIK a DLL has nothing in common with a frequency multiplier!
square wave frequency multiplier
DLLs are used to double clocks in CPLDs
Added after 13 seconds:
FPGAs
design of frequency multipliers
How to find the square root of a signal ?
square wave frequency multiplier circuit ic
Can u please explain. What is TLP ?
