fully differential opamp' s output is not symmetrical
czjpassby
Newbie level 5
beijing
dear friends:
the tran simulation of a fully differential opamp likes the following figure, the frequency of input signal is 5MHZ to obtain figure.1 and it is 100hz with figure.3. could you explain why it is not symmetrical at the begin, I wonder why it is not similiar with figure. 3. thank you very much.
figure. 1 outputs of opamp
ATTACH=CONFIG]154501[/ATTACH]
figure. 2 schematic of opamp
figure. 3
Apparently an AC coupled test setup. Looks like normal operation.
dear FvM:
thank you for your reply. can I think that is a normal results? if it is, could you tell me the reson about the undifference befor 1ms as shown in figure. 1.
Take a simple RC circuit and give it a square wave periodic input. It will take sometime for the output to settle to a periodic waveform. Its similar here.
All electrical circuits have "Temporary Time Regime" at the beginning.
thanks for all of you, I have got the reason
