akbarza
Full Member level 2
hi
i attached the pic and i saw it in a pdf in net( i do not have access to it now).
i have two question.
1) first if we disconnect feedback, namely vx is connected to a fix voltage, then is vout in phase with vin? namely does vout increased if vin is increased?
i think in this manner that if vin is increased then Ids of m1 is increased then to supply this increasing current, gate voltage of m3 must reduced. because of connection of gates m3 and m4, current of m4 increased. on the other hand , to Iss be constant, m2 current must decrease and this does by fall of drain voltage of m2. this fall of drain voltage of m2, amplifies current increase in m4. where is this current going?
is my above reasoning right?
2) in this pic is feedback negative?(Prof. Razavi had said it is negative.). how can explained that feedback is negative?
thanks
thanks
