The (sense) resistor value is based on the the current 'protection' level you want. The current through this resistor generates a voltage which is 'sensed' by the L297 (Sense1/2). If the L297 protection level is set to 0.5V (Vref input) then the maximum current allowed through the motor winding would be 1A with a 0.5 ohm resistor. With a 10 ohm resistor this would be 0.05A . So, the selection is based on the allowed current through the motor winding and the Vref you are using. A typical VRef would be 1.2V (using a 1.2V reference 'zener'). If you require a maximum current of, for example 0.5A, then your resistor would be 1.2V / 0.5A == 2.4 ohm
