Mad I.D.
Member level 1
- Joined
- Aug 21, 2009
- Messages
- 35
- Helped
- 4
- Reputation
- 8
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- Leuven, Belgium
- Activity points
- 1,506
Hi.
The circuit is attached below. It is a common current sense amplifier architecture.
For example if a want my output range to be 0-3.3V (the voltage across R2), the circuit will stop working for input voltages (I mean the rail voltage on which I'm measuring current) lower than 3.5V since there is no more Vds for the transistor left.
I know there are amplifiers on the market which work for input voltages lower than their output voltage and have the same input configuration. All they show is some current mirror between output resistor and the transistor. But still, its not a regular mirror since it would not work.
My question is. How to modify this circuit so it can provide 3.3V output on low input voltages, e.g. 0.5V?
P.S. Reducing R2 and employing another amplifier it really not a good solution. They have something better which I'm (with your help) trying to figure out.
Thanks.
Thanks.
