himanshul
Newbie level 5
Hi friends,
According to text…due to zener diode, Q1 is supplied with constant base voltage.
Any change in output voltage is sensed at at the emitter of Q1 which brings change in forward bias of the transistor. Thus transistor changes its resistance at CE junction and compensates for the voltage change at output or input.
Here transistor is acting as a variable resistor. Also total current pass through transistor hence it is also called as PASS transistor.
Q1.What all difference would it make, if I replace this zener diode with a capacitor and how would this circuit behave with a 1 Vp-p ripple is superimposed on 5V DC input signal??
I am having multiple queries regarding capacitance multiplier, will take them successively.
Source article- https://www.tpub.com/neets/book7/27k.htm
refer fig 4.34, 4.35, 4.36.
Thanks!
Thanks!
