CM108 CODEC bidirectional
HasHx
Member level 4
Good day everybody,
I need someone that has experience with the CM108B chip (Datasheet: https://www.qsl.net/om3cph/sb/CM108_DataSheet_v1.6.pdf )
I am designing a board that requires converting (SPK+ SPK- and MIC+ MIC- Analog audio signals from SIM800L module (Info: https://lastminuteengineers.com/sim800l-gsm-module-arduino-tutorial/ )) to USB 2.0, for that I am using the CM108. My question is that:
If I connect SPK for MIC and vice versa on chip, will that work? (See attached schematic)
Thanks.
