Junus2012
Advanced Member level 5
Dear friends,
Although I am not intending to use the chebyshev LPF, but it came to mind how the ripple in the passband is accepted by the ADC converter,
If I am not wrong the ripple should be below the ADCE sensitivity, in other words it should be less than 1/2 LSB error. if I take 12 bit as anexample then error should be greater than 1 mdB while mostly we employ chebyshevwith at least 0.5 dB ripple.
Thank you
Regards
Thank you
Regards
