ucah
Junior Member level 2
You can passivelly cascade the three RC sections if you do something for the interaction between them. One way is to have each resistor value be ten times larger than the previous one; the capacitors values are shaped accordingly.
You will of course end up with x100 output resistance, and you need to simulate using e.g. LTSpice.
