LUMINLABZ
avr development board
CoB is basically designed to develop a High End application device which needs an Operating System to perform the tasks. The name itself signifies as Computer on Board. The CoB consists of AVR series Microcontroller variant ATMEGA128. The main significance of this board is that a Real Time Operating System can be ported on to the Microcontroller. CoB is equipped with peripherals like Leds, Switches, 4x4 Keypad Matrix, LCD, Motor Drivers, 7-Segment Display, Buzzer, Real Time Clock and LDR. Besides these mentioned peripherals the board has facility to do serial communication with the help of serial communication protocols such as RS232, SPI and I2C. CoB is equipped with in-built regulated Power Supply and provision for variable Power Supply.
The Flash program memory supports both parallel programming and in serial In System Programming (ISP). Parallel programming mode offers gang‐programming at high speed, reducing programming costs and time to market. ISP allows a device to be reprogrammed in the end product under software control. The capability to field/update the application firmware makes a wide range of applications possible with this Board.ATMEGA128 Microcontroller is equipped with 128KB of On Chip Flash ROM and 4KB of Internal SRAM. It also has 4KB of internal EEPROM.
COB
Features
AVR ATMEGA128 with 128KB on On-Chip Flash ROM
Portability of Real Time Operating System
On-Board Regulated Power Supply of 5V
Power LED
Power Switch
Unidirectional Motor Driver
General Purpose LED’s
General Purpose Switches
4x4 Matrix Keypad
LCD Connector
Buzzer
Relays
Serial Interface supported with MAX232
Real Time Clock with CMOS Battery Backup
Sensor Port
Power Connector
Find out this Board @
LUMINLABZ
#13,11th Main,
Jayanagar 5th Block
Bangalore-560041
Ph no: 080-22451619
www.luminlabz.com
e-Mail:info@luminlabz.com
COB
Features
Power LED
Power Switch
4x4 Matrix Keypad
LCD Connector
Buzzer
Relays
Sensor Port
Power Connector
LUMINLABZ
#13,11th Main,
Jayanagar 5th Block
Bangalore-560041
Ph no: 080-22451619
www.luminlabz.com
