huytergan
Member level 3
Imagine a cavity backed crossed bow tie antenna. For RHCP, I feed each one with one coaxial probe from the bottom of the cavity. So, totally 4 ports I have, with 90 degree phase shift between each. Reference impedance and line impedance is same as 50 Ohms. Do I need a matching circuit for anything else? I already get a good return loss.
Do you think matching circuit I would need? (I read some says antenna impedance must be free space impedance(370 ohms) then a matching circuit must convert the antenna impedance to the line impedance(50 ohms).
I'm bit confused what to do
Thanks in advance
Thanks in advance
