A Question About Delta Sigma Modulators
naalald
Full Member level 4
I'm designing a 2nd order delta sigma ADC. I want to compare the systematic results with circuit design. In Matlab I have a 73 dB SNDR but in HSpice (all blocks are ideal) I have 66 dB SNDR. I don't know why? What could be the reason?
Hi
I got sigma delta modulator design (.mdl files) from my previous year student. I wanna simulate and have to calculate SNDR/SNR using matlab. I'm using hanning window to get fft. I was wondering how to calculate snr/sndr/dr from matlab.
Thanks in advance
There is maxim application note which describe the matlab routine for the spectral analysis. Check the attachment.
Otherwise there is a routine for SNR calculation in DEL-SIG toolbox. If anybody know the algorithm of this DELSIG routine, please share.
Hi naalald,
The question is too abstract to answer
If possible, share more details about your system (Schematic of both MATLAB & SPICE etc).
Hi
Thanks in advance
hi, can u please share the .mdl files of SD Modulator ???
i'm also doing a simulation of sdm.. with simulink block.. but not sure how to calcuate the SQNR. i know need to use FFT block and maybe matlab code to derive the specturm waveform.currently mine is just the simulation waveform.
