50MHz Frequency Counter using PIC16F877A
shahzadali
Newbie level 2
Problem in Practical Implementation of 50MHz Frequenct Counter (PIC16F877A)
Hello guys!
I have problem in my project: "Digital Wave Frequency Counter Using PIC16F877A". Its simulation runs very well but the problem arises when i practically implemented the project in the Lab. There is no output on the LCD instead of the glowing dot matrices whereas the microcontroller is alive as indicated by the status LED :?: The code files (microC+asm+hex) and schematic view (pdf) of the project is attatched as below
View attachment 50MHz_frq_count.zip
Simulation Done: Proteus - ISIS 7 Professional
Coding: micro C v8.2.0.0
Some of my colleagues are saying that it is due to the code which is written in microC and they are also suggesting me to rewrite the code in CCS PCWH which works correctly for the other project's groups :sad: Kindly help me in this critical situation. I shall be very thankful to you!
I have always found this page good for the LCD info **broken link removed**
