DFT shift clock and capture clock?
feel_on_on
Full Member level 5
shift and capture in dft
In the scan pattern test:
1. scan shift clock is the same clock as caputure clock ? ,and was provided by ATE clock?
2. anyone have done a At-speed test with DFT compiler or anything else
capture clock
For normal 'stuck-at' scan patterns, the shift clock is normally provided by the same source (the ATE). Using some fancy tricks, you can, for at-speed scan, enable the internal clocks to do the capture. This is usually done only if the ATE cannot provide a fast enough clock for at-speed capture, and this must be specifically designed in the clock generation circuitry.
But the ATPG tool, must understand, in any case, how to control those clocks in a deterministic way, or else it can't generate patterns.
Other than the clock-gating design mentioned above, at-speed scan is normally dealt with at ATPG time, especially with regards to mult-cycle paths, false paths and clock domain crossings. These obviously can't be tested at-speed, and are usually masked out.
John
DFT Digest
dft scan shift capture
hi,
I think it should do at-speed teste in tetramax, dftc only provide a stil protocol file and we have to modify it to adjust to at-speed test.
shift clock capture clock
u can use TK do all of them. easy to use.
