What does combinatorial loop warning mean?
EDA_hg81
Advanced Member level 2
I am using Xilinx ISE 9.1 to program Spartan3.
I got the following message : the following signal(s) form a combinatorial loop:
POL_TEMP.
What this means?
Thanks
That warning message means your design has combinatorial logic with an output feeding back to the input, forming a loop. The result is usually a latch or oscillator. Most FPGA designers want to avoid such things, so the synthesis tool warns you.
