+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 2
    Points: 1,998, Level: 10
    Join Date
    Jun 2007
    Posts
    145
    Points
    1,998
    Level
    10
    What is the difference between convolution coding and error correction coding?
    What is convolution coding. Why it is so important in digital communication. What is difference betwen convolution coding and error correction coding.
    •   Alt16th June 2007, 17:25
      advertising
  2. #2
    Advanced Member level 5
    Points: 17,526, Level: 32
    Join Date
    Oct 2005
    India
    Posts
    1,804
    Points
    17,526
    Level
    32
    covolution coding
    Convolutional codes are widely used to encode digital data before transmission through noisy or error-prone channels. During encoding, k input bits are mapped to n output bits to give a rate k/n coded bitstream. The encoder consists of a shift register of kL stages, where L is described as the constraint length of the code.
    a convolutional code is a type of error-correcting code
  3. #3
    Full Member level 5
    Points: 3,046, Level: 12
    lordsathish's Avatar
    Join Date
    Feb 2006
    Asia
    Posts
    247
    Points
    3,046
    Level
    12
    convolution coding tutorial
    It is called convolution coding because it appears as though you convolve an impulse response with the input bit sequence... its because you perform modulo 2 addition on the contents of the shift register and give them in the output...
    There are various types in such convolution coding...
    systematic--where the input sequence is a part of the output sequence
    non-systematic--where the input sequence is not a part of the output sequence
    recursive--where the output of one of the modulo 2 adders is fed back to the input of the adder itself... such that it have infinite impulse response...
    non-recursive--where there is no feedback... such that it have finite impulse response...
    1 members found this post helpful.
    •   Alt17th June 2007, 07:05
      advertising
  4. #4
    Full Member level 2
    Join Date
    Jun 2007
    Posts
    145
    Points
    1,998
    Level
    10
    shift register convolution
    Convolution coding is error corection coding. I am agree with this but the what you have explain is called hamming code most probably. Would you give me specific defination of this ( convolution coding)
  5. #5
    Full Member level 2
    Points: 1,965, Level: 10
    Join Date
    May 2007
    Chennai
    Posts
    145
    Points
    1,965
    Level
    10
    one sided noise density
    As u r performing modulo 2 addition , it is called convolution coding and the output parity bits depends on the no of message bits equal to constraint length...
  6. #6
    Junior Member level 3
    Points: 1,157, Level: 7
    Join Date
    Jun 2007
    Posts
    26
    Points
    1,157
    Level
    7
    recursive convolutional code and constraint
    Compared to linear block codes where we consider in terms of blocks of data will be send through the channel but here we can process inputs as such as they arrive. here it has the memory so that the output does not depend not only on the present input but also on the previous inputs..
  7. #7
    Full Member level 3
    Points: 3,748, Level: 14
    Join Date
    Jul 2006
    Bahrain
    Posts
    183
    Points
    3,748
    Level
    14
    modulo-2 convolutions
    Convolutional encoding with Viterbi decoding is a FEC technique that is particularly suited to a channel in which the transmitted signal is corrupted mainly by additive white gaussian noise (AWGN). You can think of AWGN as noise whose voltage distribution over time has characteristics that can be described using a Gaussian, or normal, statistical distribution, i.e. a bell curve. This voltage distribution has zero mean and a standard deviation that is a function of the signal-to-noise ratio (SNR) of the received signal. Let's assume for the moment that the received signal level is fixed. Then if the SNR is high, the standard deviation of the noise is small, and vice-versa. In digital communications, SNR is usually measured in terms of Eb/N0, which stands for energy per bit divided by the one-sided noise density.
    For more details, check this link:
    http://home.netcom.com/~chip.f/viter....html#specapps
    Ahmed
    •   Alt17th June 2007, 19:17
      advertising
  8. #8
    Member level 1
    Points: 1,462, Level: 8
    Join Date
    Aug 2005
    Posts
    39
    Points
    1,462
    Level
    8
    Re: Convolution coding
    convolutional coding is a form of error correction coding. the convolutional encoder can be considered as a shift register with desintaed outputs used to take out the encoded data. the decoding operation can be done by Viterbi algorithm.
