How to make a simple square wave generator (10 HZ to 100 HZ)
tronoty
Member level 3
555 timer square wave generator
Does anyone have a suggestion of how to make a very simple Square Wave generator that can be regulated from 10 HZ to 100 HZ (And may be up to 300 HZ).
Input Voltage is 12 Volts DC
Output can be anything between 5 Volts to 12 Volt
Duty Cycle is not so important, so 50% would be perfect
Thank you
Tronoty
555 square wave generator
The 555 timer is a very good candidate for this job ..
Use it in astable configuration, instead of fixed resistors install a potentiometer .. and off you go ..
Here:
you will find detailed description of this IC ..
Regards,
IanP
square wave generator using 555 timer
Thank you IanP for the info and the great link.
Do you know if the 555 Timer allows to keep the ON-Time the same for the frequency range?
In other words, I would like to keep the output ON-TIME at lets say 2 milli seconds from low to high frequency, so the duty cycle is constantly changing.
Possible with the 555?
Thanks
Tronoty
With the 555 you can do the opposite: the OFF time can be constant ..
Ton=0.693 * (R1+R2) * C
Toff=0.693 * R2 * C
If you vary R1 and keep R2 constant Toff will remain constant, too ..
So, if you use simple transistor inverter or NOT gate you can invert the square wave and have the ON time constant ..
Regards,
IanP
Thank you so much, this was very helpful information.
Tronoty
how to create a square wave
With regard to making a square wave gen using a 555 timer at 50% duty cycle, one way is to bypass the R2 using diodes during the charging and discharging times suitably!
Can a constant current source also be used in this case instead of R1(a current mirror circuit) which would help to produce such a wave?
how to make a wave generator
Another way to make a 50% duty cycle with the 555 is connect a 1k resistor from pin 3 to Vcc. Tie pins 2 & 6 together. Put the timing resistor from pin 3 to the junction of pins 2 & 6, put the timing capacitor from pins 2 & 6 to ground. The time now becomes: T=1.386RC.
To k7elp60:
Which means the normal resistors are not to be used in the 555 cicuit b/w pins 7 and 6 or 8! So basically, the charge is thru the resistor connected b/w pin 3 and 6, while discharge is thru the original resistor??
square wave generator schematic
coolguy_ar said:
To k7elp60:
Charge and discharge is thru the resistor connected between pins 3 and 6.
Could I get a schematic of yours please?? I just need to confirm a few things
how to make a simple generator
Schematic of 555 timer 50% duty cycle square wave
555 square wave
You can try with this circuit.
Here you have 50% of duty cycle!
Best regards.
Mr.Cube
how to make a square wave
Either 555 or PIC12F with internal clock will work.
Reactions: ZOZI
    ZOZI
how to create square wave
To Mr.Cube
Using the op-amp with unipolar supply does cause a hell lot of problems especially with the virtual ground. Plus, in your circuit, the capacitance is between the inverting input and "actual ground". Its requires that it be with the virtual gnd.
It is much better to use the op-amp using bipolar!
The following schematic is the actual one using a bipolar supply. You can probably add the resistors at the non-inverting input!
555 square wave oscillator
The output from the op-amp if used with the bipolar supply, will be positive and negative.
How do I convert this wave b/w +V and -V into a wave which is b/w +V and gnd?
It is not full-wave rectification that I want to do. And I just don't want clamping either!!
I want to "TRANSLATE" the same info contained at the original signal to the new one. Any ideas???
squarewave generator using 555 timer
Use an A-stable
50 hz square wave generator
BryanL said:
Shouldn't frequency be F=1/1.386RC as opposed to F=1.386RC
You have right, the photo has wrong notation!!
1/1.386RC is actualy the frequency
1.386RC is the period
square wave generator 555
Thank you all. this was very helpful.
I have used the 555 Timer and it worked very well.
I have used the output of the 555 to drive a small transistor and this way I get a perfect inverted signal to drive my system.
Thanks again
Tronoty
12 volt square wave
Tronoty , what values of R&C you choose
