+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Junior Member level 2
    Points: 1,186, Level: 7
    Join Date
    May 2007
    Finland
    Posts
    21
    Points
    1,186
    Level
    7
    fixed point multiply
    Hi, pals,
    I'm a green hand in VHDL and doing a very simple FFT. The first problem I encouter is how to program a 16 bits fixed point multiplier with 8 bits fraction. I don't want to use any multiplier module even they can save a huge number of logic gates. I just want to use "*" to do the multiplication.
    But since the data type is fix point with fraction, I suppose the result have to be shifted after calculation by "*". But I am not sure about that and don't know how start this program.
    Can anybody show me an example about this matter?
    Thanks a lot.
    •   Alt29th May 2007, 13:02
      advertising
  2. #2
    Full Member level 4
    Points: 3,819, Level: 14
    Achievements:
    7 years registered
    Join Date
    Sep 2006
    Posts
    199
    Points
    3,819
    Level
    14
    vhdl multiply
    First, if you are intending to use a fractional fixed notation like xxx.xxx, then you can perform multiplication by shifting each operand to the left by 8 and consider them as integers .Then, you can perform integer multiplication which can be performed by "*" .After finishing the multiplication, you must shift the result by 16 because you shifted each operand by 8 .If you only need 8 bits after the point, you can simply discard the rest of bits .
    You can also use the IEEE floating point notation i.e you can represent the number as a sign ,exponent and magnitude .You simply multiply the magnitudes together and add the exponents .Note that this formats considers the number as 1.xxxeyyy i.e after magnitude multiplication, you may need to perform shifting till you achieve only 1 before the point ,and add the number of shifts to the exponent .
    If your numbers' range is small I'd recommend the fixed point notation, but if you're expecting your system to handle large values of numbers, then you should consider the floating point notation .
    2 members found this post helpful.
    •   Alt29th May 2007, 15:33
      advertising
  3. #3
    Join Date
    May 2007
    Finland
    Posts
    21
    Points
    1,186
    Level
    7
    vhdl x001
    Thanks a lot. That's a really smart way to shift and treat it like integer.
    •   Alt30th May 2007, 09:23
      advertising
  4. #4
    Newbie level 5
    Points: 727, Level: 5
    omar_elruby's Avatar
    Join Date
    Feb 2009
    Ulm, Germany
    Posts
    9
    Points
    727
    Level
    vhdl fixed point multiplication
    I have tried this, but it's not working with me,
    i have inputs X, Y bit_vector( 9 downto 0), i'm having 7 decimal places
    mulRes <= bit_vector((signed(X) * signed(Y))); -- mulRes bit_vector(19 downto 0)
    res <= mulRes(16 downto 7);
    X = 001 1010000 "1.5"
    Y = 010 0000000 "2.0"
    mulRes = 00001101000000000000
    res = 0110100000 which is not 3 :(
    Have i understood something in a wrong way ??
    Thanks in advance :) ...
  5. #5
    Super Moderator
    Points: 239,611, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,611
    Level
    100
    how to multiply integers in vhdl
    Yes, you apparently misunderstood the concept of fractional numbers.
    This is the correct fractional representation for sfixed(2 downto -7) format
    X = 001 1000000 "1.5"
    Your example represents a different value
    X = 001 1010000 "1.625"
    Generally, you have to multiply your input number (e.g. 1.5) with a power of two to get the integer representing the fractional number.
    •   Alt3rd May 2009, 17:07
      advertising
  6. #6
    Newbie level 5
    Join Date
    Feb 2009
    Ulm, Germany
    Posts
    9
    Points
    727
    Level
    vhdl multiply by fraction
    YESSSSSSS, that's great,
    sorry i thought in a wrong way,
    It's working perfectlyyy,
    Thank you so much :)
  7. #7
    Full Member level 6
    Points: 3,477, Level: 13
    Achievements:
    7 years registered
    vipinlal's Avatar
    Join Date
    Mar 2010
    India
    Posts
    354
    Points
    3,477
    Level
    13
    HELP...fixed-point multiply using VHDL
    Read tutoRial seRies on fixed point vhdl package heRe..
    http://vhdlguru.blogspot.com/2010/03...-tutorial.html
