taring77
Full Member level 2
half controlled rectifier
Hi all,
what can i expect the output waveform of the circuit be???
if i put in the following parameters
AC source rms voltage E=208V
input AC source frequency = 60Hz
Ripple factor of HCBR is = 2%
Vo=208V
Ld=1.933mH
Cd=7747.45uF
Ci=274.9uF
i'm not so sure if i got the correct waveform. Also any experts in PSIM? or as long can see the circuit?
Hi all,
Vo=208V
Ld=1.933mH
Cd=7747.45uF
Ci=274.9uF
