current transformer..???
sam khan
Member level 1
how a current transformer works..??
and why it is never left open circuited...???
The instrument current transformer (CT) steps down the current of a circuit to a lower value and is used in the same types of equipment as a potential transformer. This is done by constructing the secondary coil consisting of many turns of wire, around the primary coil, which contains only
a few turns of wire. In this manner, measurements of high values of current can be obtained.
A current transformer should always be short-circuited when not connected to an external load. Because the magnetic circuit of a current transformer is designed for low magnetizing current when under load, this large increase in magnetizing current will build up a large flux in the magnetic circuit and cause the transformer to act as a step-up transformer, inducing an excessively high voltage in the secondary when under no load.
    sam khan
Beacuse when it under load beacuse of type of current transformer it's secondary part have very high voltage so u shouldnt left open circuited under the load
Pearson's broadband current transformer has a 50-ohm output impedance, so there's no harm in leaving it open-circuited:
I'm guessing it uses a multi-tapped winding with terminator resistors between the taps.
I just now found this diagram in Pearson's patent.
You can read the full patent, and download scanned pages: https://www.uspto.gov/patft/index.html
