Anritsu MS2601A MS2601J Spectrum Analyzer Operation Manual
pit
Full Member level 4
[No message]
anritsu ms2601a manual
Yes? What do you want to express with your comment?
    V
ms2601a manual
Thanks for manual,
do you now where i can find the service manual to ??
kind regards
anritsu ms-2601a
hamwork said:
Thanks for manual,
Here!
Service manual for Anritsu MS2601A (50 Ohm) and MS2601J (75 Ohm)
CU
  • ms2601a_j_sm_1680.pdf
Reactions: raldo
    raldo
spectrum analyzer ms2601a+user manual
Thanks for manual
Reactions: raldo
    raldo
anritsu spectrum analyzer ms2601a
Hi and thanx for the SM!
Have a MS2601A spec that dosen't work.. Have download the service manual and start to fault finding but I will trye to se if i can get some advice what i could be the "topic". If i connect the 50MHz output on the back to the input and set Fq to 50MHz and span to 200MHz i will get a normal "top" that is not locked, its flying around and if decreace the span (100KHz) the top will disappear.. One more thing is if i set Fq 0MHz, Span 0MHz and no input i will get a noice floor with sudden rise (like a mesuring a "1" TTL level with a oscilloscope) and back to the noice floor..
Both PLL LEDs Q44 and Q10 are off = locking, page 3-51.
Re: Anritsu MS2601A MS2601J Spectrum Analyzer Operation Manu
I bought a MS2601B last week, and I finally found the documentation here !
Thank you very much pit !
598 pages ! Reading in perspective for this weekend... :D
Thanks for the manuals, I have been searching for this info, much appreciated!
are there any sources for parts left?
all the best,
walter
walter2 at sphere.bc.ca
