+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Member level 3
    Points: 1,774, Level: 9
    Join Date
    Jan 2007
    Naples, Italy
    Posts
    59
    Points
    1,774
    Level
    9
    hfss driven modal driven terminal
    Could someone explain me in a very simple and clear way what's the difference between DRIVEN MODAL and DRIVEN TERMINAL solution type in HFSS?
    When should I use MODAL and when TERMINAL?
    Please, use also examples.
    Thank you!!
  2. #2
    Points: 1,020, Level: 7
    Join Date
    May 2007
    Posts
    Points
    1,020
    Level
    7
    As explained in help:
    driven terminal gives solutions in terms of voltages and current
    while
    driven modal uses power
    Added after 19 minutes:
    Specifically, Driven modal: S matrix is solved in terms of powers; Driven terminal:
    S matrix is solved based on voltages and current
    •   Alt26th May 2007, 22:06
      advertising
  3. #3
    Full Member level 4
    Points: 3,360, Level: 13
    Achievements:
    7 years registered
    Join Date
    Mar 2007
    Posts
    197
    Points
    3,360
    Level
    13
    driven modal and driven terminal
    please specify their applications!? i see both modal and terminal solution for patch antenna applications!
    it these solution have different result for one simulation?
    1 members found this post helpful.
  4. #4
    Member level 3
    Join Date
    Jan 2007
    Naples, Italy
    Posts
    59
    Points
    1,774
    Level
    9
    hfss driven model vs driven terminal
    Sorry I do not get the point.
    Could someone make some examples to show when DT is suitable with respect to DM and viceversa?
    I'll be grateful.
    Bye
    •   Alt28th May 2007, 09:32
      advertising
  5. #5
    Full Member level 1
    Points: 5,416, Level: 17
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    UK
    Posts
    105
    Points
    5,416
    Level
    17
    driven terminal hfss
    i dont know exactly the applications of both but as per my little experience they both give same results,
  6. #6
    Full Member level 5
    Points: 2,939, Level: 12
    Join Date
    Jul 2004
    Posts
    250
    Points
    2,939
    Level
    12
    hfss driven terminal or modal
    whenever u r using coaxial feed (TEM excitations) use driven terminal and whenever u r using other modes of propagation like TE/TM or quasi TEm u have to use driven modal as there may be chances of higher mode excitations also so that will give u correct results.
    Driven modal is OK for all applications
    2 members found this post helpful.
  7. #7
    Full Member level 3
    Points: 3,435, Level: 13
    Join Date
    Aug 2004
    Posts
    184
    Points
    3,435
    Level
    13
    driven terminal driven modal
    Quote Originally Posted by akedar
    The following are my experiences:
    1. When dealing with single interconnect e.g. microstrip, CPW ==> use DM.
    2. When dealing with multi-interconnect ==> use DT
    3. In DM you need to define the integration line that specifies the direction of excitation field pattern at the port. When you know exactly the field pattern, also for higher-order modes ==> use DM, when not ==> DT
    4. DT does not support the symmetric boundary condition
    5. DM does not support the FWS.
  8. #8
    Points: 917, Level: 6
    Join Date
    Jan 2008
    Posts
    Points
    917
    Level
    HFSS: driven terminal Vs driven modal
    hello
    excuseme who can help me about my Q?
    i simulated array of monopoles by HFSS and CST but their results are not compatible.
    •   Alt6th April 2010, 07:55
      advertising
  9. #9
    Junior Member level 2
    Points: 751, Level: 6
    Join Date
    Jan 2011
    Posts
    24
    Points
    751
    Level
    Re: HFSS: driven terminal Vs driven modal
    You can use both all the time. Driven Terminal is easier to set up for all conditions, so unless you really want modal s-parameter data, I suggest you use driven terminal. Driven Modal for waveguides may give better results for some cases.
    Joline.
  10. #10
    Newbie level 3
    Points: 35, Level: 1
    Join Date
    Jan 2014
    Posts
    Points
    35
    Level
    Quote Originally Posted by myemworld View Post
    Joline.
    Yes you can use both all the time. But you might get different results. If your source structure does not support TEM modes then your definition of terminal voltage is ambiguous. I would not use DT, unless the source was a multi-conductor waveguide--as indicated in the product help. Only multi-conductor waveguides can support TEM modes with well defined terminal voltages.
