cameo_2007 said:write a simple program to toggle all the port pins and check whthr it happens practically.
the purpose of doing this exercise itself is to make sure whether the IC ids good.saubhik said:be sure that in the ic no two/more pins are shorted internally - otherwise for toggling a single pin you need to check all the pins
of course! pin diagram is needed,for playing any game with itsaubhik said:. So you need the pin diagram and Constructional details of that Ic for which the testing will be done .
not clear of what you meant.can you pls put it again in simple terms.saubhik said:The other procedure is - create sample program for each input pin with its logic (which you will get from constructional details) and after adding Vcc and GND lines feed those pins the input and check that the IC is maintaining its proper function or not after checking the corresponding output pins.
zyrixx said:How do i know if my IC/controller is good or bad? is there a way to test it using VOM/DMM? thnks
Meridian said:zyrixx said:How do i know if my IC/controller is good or bad? is there a way to test it using VOM/DMM? thnks
You can use a Huntron Tracker to check the gates of an IC, in or out circuit.
