+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Advanced Member level 3
    Points: 5,901, Level: 18
    Join Date
    Feb 2002
    Pakistan
    Posts
    839
    Points
    5,901
    Level
    18
    pcad 4.53
    Hi all,
    I have desings made in old DOS based PCAD 4.51 (1989). I want to import these desings in PCAD-2001 or PCAD-2002. Can someone suggest how can this be done. Simply opening the PCB files give an error.
    thanks
  2. #2
    Junior Member level 1
    Points: 2,289, Level: 11
    Join Date
    Apr 2002
    Posts
    17
    Points
    2,289
    Level
    11
    pcad aperture
    In general:
    PCAD4.5 PDIFOUT => PCAD 200x PCB File => Import => PDIF
    It's working, bat it is necessary carefully tune up layer mapping
    [/quote]
    •   Alt12th July 2003, 09:12
      advertising
  3. #3
    Join Date
    Feb 2002
    Pakistan
    Posts
    839
    Points
    5,901
    Level
    18
    pcad 4.5 convert
    Thanks but how do I generate PDIF from PCAD. In this version (4.53), which program is used to to make PDIF files.
  4. #4
    Advanced Member level 1
    Points: 7,845, Level: 21
    klug's Avatar
    Join Date
    Jul 2002
    Posts
    476
    Points
    7,845
    Level
    21
    pdifout.exe
    To generate pdif :
    pcad45\exe\pdifout.exe file.*
    you can convert *.prt, *.sym, *.pdf, *.sch, *.ps files.
    1 members found this post helpful.
    •   Alt12th July 2003, 17:47
      advertising
  5. #5
    Join Date
    Feb 2002
    Pakistan
    Posts
    839
    Points
    5,901
    Level
    18
    view pcad 4.5 schematic
    Got it. The PCB import is smooth. Somehow I cant import PRT (pattern files). In Pattern editor, there is no import function. If I import it in the PCB program, it does import but then the screen does not show anything. Can you suggest why,
    •   Alt13th July 2003, 04:29
      advertising
  6. #6
    klug's Avatar
    Join Date
    Jul 2002
    Posts
    476
    Points
    7,845
    Level
    21
    pcad45
    I think, file convertion is not so good way at all. Some information is losted with it. Last month I have made big project on P-CAD8.7, sended *.pcb to PCB manufacturer, they converted it to P-CAD2002 and after receiving boards I have found that they have losted some polygones, changed form of few pads, and after soldering we have found that pcb is 5 mm bigger on one dimension. 8O I can not imagine how they did it. Now I am migrating to P-CAD2002.
  7. #7
    Join Date
    Feb 2002
    Pakistan
    Posts
    839
    Points
    5,901
    Level
    18
    pcad aperture .apr
    I also found some problems with losing polygons. But 5mm larger is really strange.
    I guess after porting to new versions, one needs to recheck the whole design.
    Anyone can tell me how to port patterns *.prt files.
  8. #8
    Junior Member level 3
    Points: 2,963, Level: 12
    Join Date
    May 2001
    Posts
    27
    Points
    2,963
    Level
    12
    You can bundle p-cad45 *.prt files in lib file, convert *.lib to *.pdif
    and use Library Executive | Library | Translate
    •   Alt14th July 2003, 08:43
      advertising
  9. #9
    Join Date
    Feb 2002
    Pakistan
    Posts
    839
    Points
    5,901
    Level
    18
    Tried that. The PDIF creation is OK. To try, I used a standard PCAD45 pattern library (TTL1.PLB) and converted to PDIF. But when I translate it using Library Executive Translate, it says
    "Error Fuond PDIF PCB file. Please select PDIF Library type"
    Can someone explain.
  10. #10
    Join Date
    Apr 2002
    Posts
    17
    Points
    2,289
    Level
    11
    Try next path:
    PCB 2002: File: Import: PDIF.
    After correctly completion process :
    Library => Archive Library, in PCAD2002 projects
    we get new library, which contain elements from
    project.
    From PCAD 4.5 I do not taste this path (
    Constantin
  11. #11
    Join Date
    Feb 2002
    Pakistan
    Posts
    839
    Points
    5,901
    Level
    18
    Still does not work. Has anyone actually tried this on PCAD4.5
  12. #12
    Member level 1
    Points: 3,143, Level: 13
    juggernaut7's Avatar
    Join Date
    May 2001
    USA
    Posts
    39
    Points
    3,143
    Level
    13
    I used dxf to convert Autocad polygons to copper areas and found that the conversion increased the areas by the width of the aperture. Autocad looks at the copper edge same as Pads- the actual edge of the copper, but the conversion made the edge equal to the center of a draw. Pads will back the line center away from the copper edge equal to half the aperture size used to create the copper, keeping the edge consistent.
    The bottom line is to do the conversions yourself, check them and send the vendor 274x files. Whenever you do a conversion, something always needs fine tuning and the vendor doesn't know there is a problem.
    J
