+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Member level 4
    Points: 1,760, Level: 9
    Join Date
    Aug 2005
    Posts
    78
    Points
    1,760
    Level
    9
    How to determine the emitter and collector of a transistor?
    By using a multimeter to determine the Base, Emitter and Collector of a transistor... What i get is 0.6V and 0.57V... The positive of probe is base, but how to determine the Emitter and Collector.
    •   Alt17th May 2007, 06:37
      advertising
  2. #2
    Full Member level 1
    Points: 1,767, Level: 9
    Join Date
    Dec 2006
    Nagpur - India
    Posts
    103
    Points
    1,767
    Level
    9
    BJT transistor
    by using multimeter, you will find that there is infinite resistance(open circuit) between E & C and drop across C will be more.
    1 members found this post helpful.
    •   Alt17th May 2007, 08:14
      advertising
  3. #3
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    Re: BJT transistor
    wisepie,
    The emitter to base reverse breakdown voltage is typically around 7V. You can insert a large resistor in series withe base, and measure the voltage at which the current starts to flow (avalanche current). The series resistance will prevent excessive current flow and consequent damage to the device. The terminal (E or C) that has the lowest breakdown voltage is the emitter.
    Regards,
    Kral
    •   Alt17th May 2007, 21:25
      advertising
  4. #4
    Member level 4
    Join Date
    Aug 2005
    Posts
    78
    Points
    1,760
    Level
    9
    Re: BJT transistor
    I just want to know 0.57V is terminal (E) or terminal (C)
  5. #5
    Super Moderator
    Points: 15,579, Level: 30
    E-design's Avatar
    Join Date
    Jun 2002
    Posts
    1,963
    Points
    15,579
    Level
    30
    Re: BJT transistor
    The junction with the lowest forward reading is the b-c junction. 0.57V in your case will be the b-c reading
  6. #6
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    Re: BJT transistor
    wisepie,
    Your original post doesn't make it clear under what conditions the 0.57 and 0.6V readings are measured. I'm assuming that you are somehow forcing a known current through each junction (B-E, B-C), one at a time, and measuring the diode drops. You have two phenomena that tend to counteract. On one hand, the B-C junction hase a larger area, which would tend to lower the voltage for a given current. On the other hand, the Collector region has a lower doping level than the emitter region, which would ted to increase the B-C voltage for a given current. I'm interested in knowing how E-design came to his/her conclusion.
    Regards,
    Kral
    •   Alt18th May 2007, 13:30
      advertising
  7. #7
    Super Moderator
    E-design's Avatar
    Join Date
    Jun 2002
    Posts
    1,963
    Points
    15,579
    Level
    30
    Re: BJT transistor
    I have been using this method for many years with my Fluke meter's diode testing function. The lowest reading is always the b-c junction, even if the reading differs by only 1 digit.
  8. #8
    Banned
    Points: 1,105, Level: 7
    Join Date
    Apr 2007
    Posts
    31
    Points
    1,105
    Level
    7
    BJT transistor
    The emitter will be the one with greater voltage drop and the other will obviously be collector.
