change the axis variable in Cosmos Scope
Julian18
Full Member level 3
Hi, all:
Could anyone tell me how to change the default axis variables in Cosmos Scope, from time or frequency to , say , a parameter???
Thanks
Julian.
need help. here
Added after 22 minutes:
say , i want to change the X-axis from frequency to a parameter defined by '.probe XXX = par('xxxxxxx') cammnd. How can i do that in Cscope?? help me
Hi !
Include the line ".print <analysis name- DC/AC> par <parameter name in single quotes> ".
Then in cscope, you will see the same in the signal list (the variable which you want in x-axis), click on it, then click set. Finally plot the signal you wish on y axis.
