+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 27
  1. #1
    Member level 1
    Points: 1,261, Level: 8
    Join Date
    Jan 2007
    Posts
    32
    Points
    1,261
    Level
    8
    fir filter matlab
    Can anybody help to find our FIR filter design for random noise removal.
  2. #2
    Full Member level 3
    Points: 2,199, Level: 10
    Join Date
    Dec 2006
    Posts
    165
    Points
    2,199
    Level
    10
    matlab noise filter
    What is the type of filter you want? You can use the filter design tool box that comes with matlab (check matlab help).. A simple cammand fir will design the filter for you..
    1 members found this post helpful.
  3. #3
    Member level 1
    Points: 1,577, Level: 9
    Unomano's Avatar
    Join Date
    Aug 2005
    Minsk, Belarus
    Posts
    40
    Points
    1,577
    Level
    9
    fir matlab
    What kind of signal do you use? Filter must be matched to your signal.
  4. #4
    Full Member level 2
    Points: 1,973, Level: 10
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Posts
    134
    Points
    1,973
    Level
    10
    fir filter matlab code
    Your FIR should be a low pass in nature, but the specification has to be extracted from noise spec.
    •   Alt13th April 2007, 08:55
      advertising
  5. #5
    Full Member level 2
    Points: 2,500, Level: 11
    helios's Avatar
    Join Date
    Jun 2005
    Posts
    147
    Points
    2,500
    Level
    11
    matlab fir
    in general cases
    Find the noise variance or estimate it
    use the "fspecial" to design u r quick gaussian filter
    might work easily ..but it depends of the noise distribution...
    If u want a real good answer....u r questions must be very specific
  6. #6
    Full Member level 1
    Points: 1,550, Level: 8
    Join Date
    Jan 2007
    Posts
    107
    Points
    1,550
    Level
    8
    noise filter matlab
    Quote Originally Posted by ztanish
    please you want filter noise in what frequency?
  7. #7
    Newbie level 3
    Points: 1,041, Level: 7
    Join Date
    Mar 2007
    Posts
    Points
    1,041
    Level
    7
    matlab filter noise
    use fdatool in Matlab
    >> fdatool
    br
    •   Alt17th April 2007, 11:43
      advertising
  8. #8
    Points: 1,053, Level: 7
    Join Date
    Apr 2007
    Posts
    7
    Points
    1,053
    Level
    7
    matlab code for fir filter
    Filtering noise through a simple Low Pass filter will be a naive method but its a good step if its your first try.
    As a first step check out "fir1" in matlab.
    bye.
    •   Alt17th April 2007, 15:02
      advertising
  9. #9
    Member level 1
    Points: 1,985, Level: 10
    Join Date
    Dec 2006
    Posts
    32
    Points
    1,985
    Level
    10
    filter noise matlab
    Use FDATOOL in matlab. If you type
    >> fdatool
    in command window, Fda tool will be opened. There you can select FIR or IIR filter, order of filter and cutoff freq. of filter (either HPF, LPF or BPF). That code will automatically generate .m file for you.
  10. #10
    Junior Member level 3
    Points: 1,490, Level: 8
    Join Date
    Jan 2007
    Posts
    25
    Points
    1,490
    Level
    8
    matlab fir filter
    Try this " help firwiener " and read how to use. This is easy step to filtering noise and no need to design in "fir" function learn it as benchmark, then u should design parameter of "fir1" for filtering by yourself.
  11. #11
    Newbie level 6
    Points: 1,321, Level: 8
    Join Date
    Apr 2007
    Posts
    14
    Points
    1,321
    Level
    8
    matlab fir filter design
    Quote Originally Posted by maomun
    tanks for help
  12. #12
    Member level 1
    Points: 1,368, Level: 8
    Join Date
    Jul 2006
    india
    Posts
    38
    Points
    1,368
    Level
    8
    fir filter in matlab
    try using matlab for moving avg filters
    2 members found this post helpful.
  13. #13
    Member level 3
    Points: 1,569, Level: 9
    armess's Avatar
    Join Date
    Sep 2006
    Posts
    64
    Points
    1,569
    Level
    9
    matlab program for fir filter
    give ur email id i 'll send the code to u as a .m file.
  14. #14
    Full Member level 3
    Points: 2,123, Level: 10
    Join Date
    Jun 2005
    Posts
    186
    Points
    2,123
    Level
    10
    matlab fdatool
    you should know what type filter matched to your apllications, LPF,BPF,or HPF, then you should know what charateristic the filter have , such as cut off frequency , ripple wave in passband and attenuation! wish it helps !
  15. #15
    Newbie level 2
    Points: 935, Level: 6
    Join Date
    Sep 2007
    Posts
    Points
    935
    Level
    fdatool matlab
    can u please giv me the code which u had recived...........i hav a project to do
    send tat to my mail id tejaswi.subash@gmail.com
    Added after 5 minutes:
    Quote Originally Posted by cydi
    can u giv me the code which u recived tat is matlab code for fir filter design as i hav aproject to do.please do help me
    my email id is tejaswi.subash@gmail.com
    Added after 29 seconds:
    Quote Originally Posted by Unomano
    thank you
    Added after 10 seconds:
    thank you
    Added after 1 minutes:
    Quote Originally Posted by helios
    in general cases
    Added after 49 seconds:
    Quote Originally Posted by armess
    give ur email id i 'll send thcan u giv me the code which u recived tat is matlab code for fir filter design as i hav aproject to do.please do help me
    my email id is tejaswi.subash@gmail.come code to u as a .m file.
    Added after 54 seconds:
    Quote Originally Posted by sprao
    >> fdatool
    in command window, Fda tool will be opened. There you can select FIR or IIR filter, order of filter and cutoff freq. of filter (either HPF, LPF or BPF). That code will automatically generate .m file for youcan u giv me the code which u recived tat is matlab code for fir filter design as i hav aproject to do.please do help me
    my email id is tejaswi.subash@gmail.com.
  16. #16
    Newbie level 1
    Points: 596, Level: 5
    Join Date
    Aug 2009
    chennai
    Posts
    Points
    596
    Level
    noise filtering matlab
    clear all;
    close all;
    rp=input('enter the pass band ripple');
    rs=input('enter the stop band ripple');
    fp=input('enter the pass band ferquency');
    fs=input('enter the stop band frequency');
    f=input('enter the sampling frequency');
    wp=2*fp/f;
    ws=2*fs/f;
    num=-20*log10(sqrt(rp*rs))-13;
    dem=14.6*(fs-fp)/f;
    n=ceil(num/dem);
    n1=n+1;
    if (rem(n,2)~=0);
    n1=n;
    n=n-1;
    end
    y=boxcar(n1);
    b=fir1(n,wp,y);
    [h,o]=freqz(b,1,256);
    m=20*log10(abs(h));
    subplot(2,2,1);
    plot(o/pi,m);
  17. #17
    Points: 15,530, Level: 30
    Aya2002's Avatar
    Join Date
    Dec 2006
    Iraq
    Posts
    1,142
    Points
    15,530
    Level
    30
    fir filter design matlab
    Quote Originally Posted by pranchith
    clear all;
    close all;
    wp=2*fp/f;
    ws=2*fs/f;
    dem=14.6*(fs-fp)/f;
    n=ceil(num/dem);
    n1=n+1;
    if (rem(n,2)~=0);
    n1=n;
    n=n-1;
    end
    y=boxcar(n1);
    b=fir1(n,wp,y);
    m=20*log10(abs(h));
    subplot(2,2,1);
    plot(o/pi,m);
    please run it and give us the input with the output
    thanks
  18. #18
    Advanced Member level 3
    Points: 9,408, Level: 23
    Join Date
    Oct 2008
    Sindh, Pakistan
    Posts
    895
    Points
    9,408
    Level
    23
    fir in matlab
    for good results you may want to use either Kaiser's or Blackman's window. The rectangular window wold not give good attenuation in the stop band
  19. #19
    Newbie level 2
    Points: 548, Level: 4
    Join Date
    Nov 2009
    N.I.T.,kurukhetra
    Posts
    Points
    548
    Level
    Re: Matlab code for FIR filter design
    i want a matlab code for filter design using kaiser window
  20. #20
    Newbie level 3
    Points: 649, Level: 5
    Join Date
    Jun 2009
    bangalore
    Posts
    Points
    649
    Level
    Re: Matlab code for AWGN filter
    Hi all.
    i have added AWGN to my speech signal, how to filter it out,?
    how to know the frequency of the gaussian noise that i have added, plz do reply
    •   Alt19th March 2010, 06:51
      advertising
