+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Points: 1,037, Level: 7
    Join Date
    Apr 2007
    Posts
    Points
    1,037
    Level
    7
    atmel 2313
    Hello All,
    This is great forum to be a member. I am very newbie and I need help on how to flash ATTINY 2313 Atmel IC? Which programmer do I use? Do any programmer out there to buy and if there is schematics to build my own programmer?
    Sorry for few questions,
    Thnx..
    JR
  2. #2
    Advanced Member level 2
    Points: 7,314, Level: 20
    Join Date
    Dec 2005
    Posts
    651
    Points
    7,314
    Level
    20
    attiny2313 flash
    There are lots of programmers for this chip. The determining factor of which to build is whether you have a dedicated parallel port available or not. USB to parallel port adapters will not work. You need a parallel port on the motherboard. If so, then
    http://www.scienceprog.com/avr-isp/
    is one example of a simple DYI programmer. There are lots of other variations and alternative circuits. BASCOM BASIC software can run some programmers. Avrdude from WINAVR can also be configured for a lot of different parallel port programmers. Another programming software is PonyProg. Research these and you will find schematics for the hardware.
    If you only have available serial ports, then most likely you will have to purchase a programmer. The reason is, the programmer requires a programmed microcontroller as one of this components. So, it is like the chicken and the egg. You need the programmed part to build the programmer and you need a programmer to program the part.
    •   Alt7th April 2007, 01:00
      advertising
  3. #3
    Join Date
    Apr 2007
    Posts
    Points
    1,037
    Level
    7
    atmel attiny programmer
    Hi Banjo,
    Thanks for the reply, and thanks for the link.
    I did check that link and I do have Parallel Port but I do have few exactly following IC when I read from top of these IC.
    ATMEL 0606
    ATTINY2313V-10PU
    It has total of 20 LEGS IC. and its DIP but not surface mount.
    I also has two COM1 and COM2 Port.
    How do I make 20 PINS programmer?
    Please help me to make this programmer.
    Thnx for your help buddy..
    JR
  4. #4
    Newbie level 2
    Points: 1,032, Level: 7
    Join Date
    Mar 2007
    Posts
    Points
    1,032
    Level
    7
    atmel 2313 programmer
    i use a program called pony prog to flash the attiny2313. it uses it's own programer that you can build at home for about $10. it's a serial programer. i forgot the website, but i'm pretty sure if you just google it you'll find it. good luck.
    •   Alt7th April 2007, 04:03
      advertising
  5. #5
    Join Date
    Apr 2007
    Posts
    Points
    1,037
    Level
    7
    2313 atmel
    Hi Jimmy,
    I have following link to buy that type of Programmer.
    http://www.sparkfun.com/commerce/pro...products_id=14
    Is this correct one? How do I plug my 20 PINS ATTINY2313 IC?
    Thanks for your help and sorry, I am just newbie and try to learn and understand.
    Thnx,
    JR
    Added after 39 minutes:
    I just want to verify, is this the right one?
    http://shop.gtronica.com/product_inf...roducts_id=267
    Thnx,
    JR
  6. #6
    Newbie level 2
    Join Date
    Mar 2007
    Posts
    Points
    1,032
    Level
    7
    atmel flash
    there will be a 20 dip socket on the programmer, you just put your t2313 into it, then when you're done programming, just pull it out, and put it into what ever you're going to use it in. i suggest using a ic puller to pull it, but if you don't have one just pry it out slowly with something flat like an xacto. it's kind of hard to pull it out of the socket by hand and not bend the pins.
    oh by the way there are 2 versions of the programmer. try to find the one that's a single sided pcb, and it's a single board. don't get the one that uses all the doogles.
    Added after 20 minutes:
    alright, since i'm bored and had nothing to do. i decided to help you with some of the leg work.
    o.k. first go here to download the pcb image:
    h**p://www.electronics-lab.com/projects/mcu/009/index.html
    download the pdf file. and the use the last image. that's the bottom side of the pcb. the fist image is the topside, and the middle one is the silkscreen.
    then go here to download the latest version:
    h**p://www.lancos.com/
  7. #7
    Advanced Member level 1
    Points: 5,008, Level: 16
    Join Date
    Jan 2003
    Posts
    424
    Points
    5,008
    Level
    16
    flash attiny2313
    check here. you will find plenty of programmers for AVR microcontrollers
    h**p://www.avrfreaks.net/index.php?module=FreaksTools&func=viewTools&q=&category_id=57
  8. #8
    Join Date
    Apr 2007
    Posts
    Points
    1,037
    Level
    7
    attiny bascom
    Hi Jimmy,
    Thanks for your two links, its really help me to build myself.
    However, I do have few questions before start builiding.
    1. Do I need following IC before start flashing my ATTINY2313?
    U1 ?
    U2 I needed for sure.
    U3 ?
    U4 ?
    U5 ?
    U6 ?
    Rest of those parts I do need but I have above is in questions.
    I really appreciated for your time and help.
    Thnx,
    JR
    •   Alt8th April 2007, 02:10
      advertising
  9. #9
    Join Date
    Apr 2007
    Posts
    Points
    1,037
    Level
    7
    programming atmel attiny2313
    Any advice?
  10. #10
    Join Date
    Apr 2007
    Posts
    Points
    1,037
    Level
    7
    www.atmel 89s8252 ic programer in n c r
    Hi Jimmy,
    U1 ?
    U3 ?
    U4 ?
    U5 ?
    U6 ?
    Thnx,
    JR
