+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 4
    Points: 2,896, Level: 12
    Join Date
    May 2006
    Cairo - Egypt
    Posts
    233
    Points
    2,896
    Level
    12
    ICD-2 error: Invalid target device id (expected=0xD4, read=0x0)
    hello all
    i am using a pic 18f4580 with the icd2, and i am putting it in a circuit powered by 5 v regulated supply and the MCU and 16 MHZ crystal and led.
    when i connect the icd2 to the mplab (in either programmer or debugger mode , i get the following error :ICDWarn0020: Invalid target device id (expected=0xD4, read=0x0), i always get validation error, such that every expected variables is read as zeros, which prohibit debugging and programmin).
    i tried to program the MCU with a program to turn on the led (using another programmer). and then place the MCU in the debugging crcuit again so the led is on and after connecting the icd2 it is off (mclr is down) then in mplab when i choose the programmer settings to release from reset mode, the led lights again (all i want to tll is that all tests of the connection from the icd2 to MCU is good), so what is the problem , why he reads anything as zero.
    Thanks in advance
    •   Alt6th April 2007, 20:56
      advertising
  2. #2
    Full Member level 1
    Points: 2,727, Level: 12
    Join Date
    Nov 2004
    Balen (Belgie)
    Posts
    111
    Points
    2,727
    Level
    12
    ICD-2 Problem
    I have a similar problem with my ICD2, after changing the serial resistors 330 ohm to 100 ohm the problem was gone.
    •   Alt7th April 2007, 12:22
      advertising
  3. #3
    Advanced Member level 2
    Points: 4,896, Level: 16
    UroBoros's Avatar
    Join Date
    May 2004
    Cochin - India
    Posts
    633
    Points
    4,896
    Level
    16
    Re: ICD-2 Problem
    Hi
    Please check
    see the results on self check,is all test passed?
    see the connections on PGC and PGD ,any pull ups or any loads on that line?
    is there any large decoupling capacitors on MCLR?
    stay in programmer mode until you get valid id , then to debugg mode.
    If not ok in debugg, check crystal.
    make sure PGC and PGD pins are not reversed (:D )
    all the best
    picstudent
    •   Alt7th April 2007, 14:56
      advertising
  4. #4
    Advanced Member level 5
    Points: 14,575, Level: 29
    blueroomelectronics's Avatar
    Join Date
    Sep 2006
    Toronto, Canada
    Posts
    1,686
    Points
    14,575
    Level
    29
    Re: ICD-2 Problem
    Quote Originally Posted by Picstudent
    There should be no caps of any sort on MCLR when using ICP
    I had students with 10uf on MCLR and of course it failed any attempt at programming / debugging whatever. No caps period, you don't need them on MCLR. You DO need caps 0.1 near the power & gnd pins on the PIC and any other digital IC.
  5. #5
    Full Member level 4
    Join Date
    May 2006
    Cairo - Egypt
    Posts
    233
    Points
    2,896
    Level
    12
    Re: ICD-2 Problem
    Hi
    Please check
    all the best
    picstudent
    Thanks al ot for your reply,
    As an answer to your questions:
    1- yes, it passes all self test
    2-PGC,PGD connections are all identical to that in the manual
    3-no caps at MCLR at all
    Hpwever when i tried to power the circuit from the ICD-2, it goes well, but when i my circuit is self powered, the same problem occurs
    Does anybody know why?
  6. #6
    Full Member level 1
    Points: 2,214, Level: 10
    Join Date
    Apr 2006
    Under Mango Tree
    Posts
    95
    Points
    2,214
    Level
    10
    Re: ICD-2 Problem
    Quote Originally Posted by blueroomelectronics
    No need of capacitors on MCLR while debugging or programming, agreed.
    But, On working prototype I had somany bad experiences by removing the capacitor from MCLR.
    for example, if you are driving an inductive load like contactor, it will produce unwatned noise and cause the PIC reset itself.
    •   Alt8th April 2007, 16:15
      advertising
  7. #7
    Newbie level 2
    Points: 1,083, Level: 7
    Join Date
    Apr 2007
    China
    Posts
    Points
    1,083
    Level
    7
    ICD-2 Problem
    I met this problem many many times when I learned PIC two years ago.I think your mpu's connection is't right.Please try to get a board placing only one PIC and connect PIC to ICD2.
  8. #8
    Banned
    Points: 22,963, Level: 36
    Join Date
    May 2007
    USA & Canada
    Posts
    437
    Points
    22,963
    Level
    36
    ICD-2 Problem
    Did you checked the resistors in the MCLR
