+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Points: 1,456, Level: 8
    Join Date
    Jan 2005
    Posts
    Points
    1,456
    Level
    8
    omnidirectional antenna
    hi all
    Is it possible to design an omni directional circularly polarized microstrip antenna using single fed ?
    I'm using HFSS and I had some ideas, but the results are still bad.
    Can you give me some advices?
    Thanks
    •   Alt6th April 2007, 19:12
      advertising
  2. #2
    Member level 1
    Points: 1,181, Level: 7
    Join Date
    Feb 2007
    Posts
    34
    Points
    1,181
    Level
    7
    mwjournal circular polarized patch antenna design
    i dont know abt hfss
    but in pcaad u can design
    •   Alt7th April 2007, 11:27
      advertising
  3. #3
    Full Member level 1
    Points: 2,837, Level: 12
    Join Date
    Jun 2004
    India
    Posts
    113
    Points
    2,837
    Level
    12
    how to make omnidirectional microstrip antenna
    check this link out for circular polarization. Obviously, this cant be used on a patch because it won't be omnidirectional but its a good read for any antenna design engineer anyway.
    http://www.mwjournal.com/Journal/art...p?HH_ID=AR_453
    •   Alt10th April 2007, 12:01
      advertising
  4. #4
    Full Member level 4
    Points: 2,910, Level: 12
    Join Date
    Feb 2005
    Posts
    195
    Points
    2,910
    Level
    12
    how to buildan omnidirectional antenna
    I am also doubt about whether there exists omni-directional circular-polarization antenna, not matter in what forms.
    Since I reviews all the antennas I know for circular polarization, such as microstrip antenna, helix antenna and so on, all of them are only broadside or endfire, but not omni-directional.
    I am not sure whether the antenna arrays can generate the pattern with omni-directional circular polarization, but I think even it would, at some angle the axial ratio should be not acceptable.
  5. #5
    Advanced Member level 3
    Points: 9,181, Level: 22
    Join Date
    Sep 2003
    Posts
    868
    Points
    9,181
    Level
    22
    omnidirectional antenna lhcp
    Hi:
    I am afraid there may not be any omni-directional antenna for circular polarization. Normally, if an antenna is RHCP in one direction, it will be LHCP in the opposite direction. From RHCP to LHCP, there will be a point with no radiation or with linear polarization only. Otherwise, it can transit from RHCP to LHCP. Regards.
  6. #6
    Advanced Member level 5
    Points: 32,294, Level: 43
    Join Date
    Oct 2001
    Posts
    4,623
    Points
    32,294
    Level
    43
    build omnidirectional antenna
    There is possible to build an omni-directional antenna for circular polarization, but unfortunately not in microstrip.
    http://www.ee.kth.se/php/modules/pub...S3-EX-0523.pdf
    http://members.aol.com/k5oejerry/eggbeater2.htm
    •   Alt11th May 2007, 20:26
      advertising
  7. #7
    Points: 33,086, Level: 44
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,646
    Points
    33,086
    Level
    44
    omnidirectional circular polarization antenna
    Sure. There are planar types of antennas for omindirectional dual polarization. Here is one at low frequency for use on an airplane. You could make the same type of antenna in microstrip. I am no antenna expert, but I think the crossed slot antennas need a resonant structure on the ground plane side.
  8. #8
    Points: 9,828, Level: 23
    Achievements:
    7 years registered
    Join Date
    Feb 2007
    All over the Map.
    Posts
    1,075
    Points
    9,828
    Level
    23
    dual polarized omnidirectional antenna
    Circularly polarized omnidirectional antennas are possible. One type is a Lindenblad. It however is not strictly planar.
    I can imagine an antenna using a planar patch element producing circularly polarized energy in a somewhat focused beam. Place the patch in the horozontal plane and let it radiate upwards along the z axis. Now place a cone with the vertex at the origin so that it spreads the beam into the horizontal plane and you have a circilarly polarized omni-directional antenna. Strictly this is omni in the xy plane which is often what is intended.
    I have used this technique with a turnstile instead of a patch. It does work.
    Other possibilities also exist. Consider the wide types of GPS antennas these are generally hemispheric in their coverage and RHCP. A quadrifilar helix is a particularly good type here.
