+ Post New Thread + Mark as Unsolved
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 20 of 74
  1. #1
    emdee
    crownhill proton + basic compiler
    I have tried sereral Basiccompilers for the pic. Most compilers had bugs..or compile very large sode for simply instructions...
    Anyone know what's a good compiler?
    Emdee
    Chordstar@hotmail.com
  2. #2
    Junior Member level 1
    Points: 2,530, Level: 11
    Join Date
    Jul 2001
    Posts
    16
    Points
    2,530
    Level
    11
    proton mikrobasic pic basic comparison
    Have you used PicBasic Pro? The
    newer the version, the tighter the
    produced code seems to be. With 2.33
    the generated code is often as small
    (or smaller) than my own ASM code (which
    I'm still struggling to learn).
    Which BASIC compilers have you tried?
    Kal
  3. #3
    sick_man
    ch flash basic
    i can give some good tips to learn asm fast
    1) make idiot cards {i have several}
    they are all over the walls i made a tape with just a list of the commands and a routene about there routine a good explination
    followed by a tape of a microchip lecture {they send you free anywhere a disk set if you ask them via the web on it is a few lectures on asm}
    may i say that this company in
    THEE most helpfull comany of good old usa
    and i mean it a close second is analogue
    so make a tape or cd rom and play it till it completely makes you sick
    then put it asside and read a book on c++
    to see what commnads look similar or do the same thing
    like having two dictionary's to learn a language not one
    also the command description is like a mixture between a desctripton and what you must add
    a shape every language has one
    its
    "structure" then go back to the tape or cd for a week to refresh
    you know have it in your subconcious
    this time do it awake infront of the cpu while you look to an advanced destription
    the idiot card and the large mug of coffee
    you make before you takle
    a small project
    then a bigger one
    then if your wife and kids {or cat or dog or mother} leaves you alone long enough
    it becomes a bit like fishing
    and very pleasurable to write
    so iron out the wrinkle on your forehead
    and dont work fast
    to avoid errors work a bit like a news man
    and an avertising agent
    this is where pic basic was born
    collect the code blocks you know and use
    int convinient macros many ide and compilers support them in many c and even hex
    {dont be scard to learn to program in hex it can be fun too
    and quite a challange
    the first sort of language i learned
    was sinclair scientific calculator
    "brainless but not much more stupid than a pic infact basicaly the same "
    asm is easy as long as you learn the stucture of a lanuguage by its detract connections
    just like a compiler in reverse
  4. #4
    Junior Member level 3
    Points: 2,489, Level: 11
    Join Date
    Jun 2001
    Earth
    Posts
    29
    Points
    2,489
    Level
    11
    arabic basic compiler
    Write Your Own ?
  5. #5
    Join Date
    Jun 2001
    Earth
    Posts
    29
    Points
    2,489
    Level
    11
    best picbasic compiler
    Hey why are you so much intrested in basic compiler for PIC ?
    Disadvantages of Basic compiler is non portable code unless you have basic compiler for other arch.
    Try to use c compiler for writting portable code. In most cases you will find a good or bad C compiler for all uC arch.
    Regards.
    Zastereo
    •   Alt22nd July 2001, 09:26
      advertising
  6. #6
    ch flash basic for pic
    I think that the Melabs Picbasic Pro compiler is the best one for pics
    but new letbasic compiler.....
  7. #7
    Points: 2,685, Level: 12
    Join Date
    Jan 2000
    Posts
    17
    Points
    2,685
    Level
    12
    basic compilers for pic
    PICBASIC PRO
    I think it is the best choice!
  8. #8
    Newbie level 6
    Points: 4,272, Level: 15
    Join Date
    May 2001
    Poland
    Posts
    11
    Points
    4,272
    Level
    15
    best pic basic compiler
    I'm using microEngineering Labs PicBasicPRO 2.40
    In my mind is the best
    Regards, Freddy
  9. #9
    Points: 4,347, Level: 15
    Join Date
    Feb 2002
    Posts
    18
    Points
    4,347
    Level
    15
    crownhill proton picbasic
    Also Ch flash basic compiler is a good compiler.
  10. #10
    Points: 4,474, Level: 15
    Join Date
    May 2001
    between France and Poland :-)
    Posts
    30
    Points
    4,474
    Level
    15
    ch flash basic compiler for picmicros
    hy,
    Is the IAR Pic C-Compiler better then the Pic Basic Pro one ? (into Code size), and
    does someone have a link to it?
    greetings
    mc_eddy
    •   Alt3rd March 2002, 20:52
      advertising
  11. #11
    Newbie level 6
    Points: 2,421, Level: 11
    Join Date
    May 2001
    Posts
    11
    Points
    2,421
    Level
    11
    oshonsoft basic compiler
    Agree with Freddy
  12. #12
    Member level 1
    Points: 2,366, Level: 11
    Join Date
    Jun 2002
    Posts
    38
    Points
    2,366
    Level
    11
    explanation of proton + basic compiler
    8) HI ALL
    I want ***** for "CH flash basic 1.7 " copplier .
    Pls help .
    Thanks...
  13. #13
    Points: 2,025, Level: 10
    Join Date
    Dec 2002
    Posts
    26
    Points
    2,025
    Level
    10
    crownhill proton suite
    It can ve changed according to everone's classical programming choices. For example i love basic routines therefore i like picbasic.
  14. #14
    Advanced Member level 3
    Points: 6,852, Level: 19
    SphinX's Avatar
    Join Date
    Jan 2002
    EGYPT
    Posts
    822
    Points
    6,852
    Level
    19
    best basic compiler for pic
    Here is review for PIC BASIC PRO
    http://www.rebel.net.au/~drew/picuse.../PicBasic.html
    Pharaoh Of Egypt
  15. #15
    Advanced Member level 5
    Points: 36,491, Level: 46
    flatulent's Avatar
    Join Date
    Jul 2002
    Middle Earth
    Posts
    4,629
    Points
    36,491
    Level
    46
    pic basic compiler oshonsoft
    One advantage of PICBasic and PICBasic Pro is the large number of after market tutorial and project books available.
    http://www.melabs.com/products/books/index.htm
    Has an example of several.
  16. #16
    Member level 4
    Points: 2,696, Level: 12
    debutpic's Avatar
    Join Date
    Aug 2001
    Posts
    76
    Points
    2,696
    Level
    12
    code designer pic basic
    if you use Pic Basic Plus compileur (C*r*o*w*n*h*i*l*l)
    you can debug basic source in P*r*o*t*e*u*s V*S*M
    look L*a*b*c*e*n*t*e*r's page
    debutpic
    •   Alt28th December 2002, 11:44
      advertising
  17. #17
    Member level 5
    Points: 3,596, Level: 14
    Join Date
    May 2002
    Posts
    80
    Points
    3,596
    Level
    14
    free picbasic compiler
    Hi people ,
    I think the best choice is PIC BASIC PRO COMPILER and u can get an IDE interface for it from
    www.melabs.com called CD LITE.................
    PLus u can down load its compiler in pdf or html form this site aswell........
    if any one need it just send me a mail I will upload it upon request.......
    Bye..... :)
  18. #18
    Advanced Member level 2
    Points: 7,635, Level: 20
    Mr.Cool's Avatar
    Join Date
    Jun 2001
    Posts
    664
    Points
    7,635
    Level
    20
    compiler crownhill
    it is NOT true that pic basic pro produces "non-transferable" code. in the compiler options of version 2.42 you can select "produce assembly code".
    for sh*ts and giggles, you can also produce the assembly code right after the basic code (which you wrote) so you can see the difference. great learning tool!!!!
    for more info on this subject read the pic basic pro compiler manual found at w*w.melabs.com
    Mr.Cool
  19. #19
    Member level 1
    Points: 2,326, Level: 11
    Join Date
    Sep 2002
    Posts
    37
    Points
    2,326
    Level
    11
    comparing proton compiler with other compilers
    I think picbasic plus is the best, and picbasic pro is the second one. I tried picbasic pro but now i'm using hitech c compiler. I think good choice is picbasic plus.
  20. #20
    Points: 2,912, Level: 12
    Join Date
    Jul 2002
    Posts
    28
    Points
    2,912
    Level
    12
    top rated basic compiler
    For a more detailed comparison between Pro and Plus! Click
    http://www.letbasic.com/item585.htm
    for a Flash presentation.
    I vote for PicBasic Pro!!!
