Thank you! I tried to increase/decrease the bias current of the active device ,so the gm chaged ,but the negative resistor changed little,almost the same as before.khouly said:manily the negative resistance is dependent on the gm of the active device , so by controlling the gm ucan control the negative resistance value
khouly
