+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 4
    Points: 2,147, Level: 10
    Join Date
    Jul 2006
    Posts
    217
    Points
    2,147
    Level
    10
    What does Burst Mode......Burst Transfer...refers to?
    hi everyone.........
    Thanks
    •   Alt15th March 2007, 13:07
      advertising
  2. #2
    Advanced Member level 2
    Points: 5,794, Level: 18
    Join Date
    Aug 2005
    Posts
    682
    Points
    5,794
    Level
    18
    SDRAM, when issue one command read/write and able to read/write 2/4/8/ full page of data
  3. #3
    Member level 2
    Points: 1,391, Level: 8
    Join Date
    Dec 2006
    Posts
    43
    Points
    1,391
    Level
    8
    Re: What does Burst Mode......Burst Transfer...refers to?
    if u want to write in continnous memory locations it is useful
    •   Alt16th March 2007, 04:15
      advertising
  4. #4
    Full Member level 4
    Join Date
    Jul 2006
    Posts
    217
    Points
    2,147
    Level
    10
    sry i could n't get you ..............plz
    can you be more specific in the way you describe it.........
    i mean what is that 2/4/8 signify............
    thanks
  5. #5
    Member level 4
    Points: 1,658, Level: 9
    go4sandesh_vsn's Avatar
    Join Date
    Sep 2006
    Pune, India
    Posts
    77
    Points
    1,658
    Level
    9
    hi Guru
    Letz start from the very basic of memory accesses. When u want to access a single memory location at a time, what u do is tht u just specify the memory location (and the data to be written in case itz a write operation) and that it will be done. Again if u want to access another location u do the same. U know when u give address this way (one at a time), then each time the access will take same time (including accessing that location + reading/writing).
    But since we know memory accesses are very slow compared to CPU speed, so a lot of time is wasted in case u want to read say contiguous memory locations and u provide those contiguous locations one at a time.
    We can see it this way....say a memory read access takes say N memory cycles ...then if u want to read say M locations n u provide one address at a time...then it will take N*M memory cycles (ideally) for the entire access. Right. But if u really c its a whole lot of time....n we r not gaining anything even if the locations being contiguous.
    By this wat i mean to say is that normally in SDRAMs, the access to a memory location is by first opening a particular row, followed by accessing the intended column in that row...n then that row is closed after access. So if u want to read say 4 contiguous locations a time (meaning 4 adjacent columns say N to N+4 of the same row say row no. R) then if u provide all those locations one at a time, then for every access, it will first take some time to open row R , then will access the column N, then will take time to close row R. Again for accessing column N+1 , it will again take time to open row R, then some time to access column N+1, then again will close row R.....
    SO u can see unnecessarily its opening n closing the same row again n again n wasting time in that ( when we know that the locations are adjacent )....So a better option is to go for so called BURST MODE...where u just need to give input for once only in the form ofrow address, 1st column address, n the no. of columns to access. Wat SDRAM will do is tht it will open the row for the first time, n then will access columns one after the other without closing the row....n when finally all columns r accessed it will close that row.....
    Here watever i said may be not exactly correct in terms of say u cant access any no. of colums (normally its 2 or 4 or 8 or the entire row)....but overall i suppose u'll wat i mean to say....
    in case any doubts ...feel free to ask.....
    u can also go thru this pdf...plz go thru the timing diagrams for Burst mode access (read/write)
    http://www.datasheet4u.com/download.php?id=502209
    or
    http://www.datasheet4u.com/html/M/T/...icron.pdf.html
    2 members found this post helpful.
    •   Alt16th March 2007, 08:06
      advertising
  6. #6
    Member level 4
    Join Date
    Sep 2006
    Pune, India
    Posts
    77
    Points
    1,658
    Level
    9
    though it may seem like a lot to read....but i suppose its quite easy to understand...so in case u hav time....just go thru it once...at least u'll get the very basic idea of Burst Mode....
  7. #7
    Newbie level 1
    Points: 13, Level: 1
    Join Date
    Jul 2014
    Posts
    Points
    13
    Level
    the post is really good my doubt is why are the address's given in power's of 2 and not odd numbers.
