+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Junior Member level 2
    Points: 1,863, Level: 10
    Achievements:
    7 years registered
    mago's Avatar
    Join Date
    Jan 2006
    Posts
    23
    Points
    1,863
    Level
    10
    erase code protected pic
    Hi everybody,
    Does anyone know how to chip erase the pic16f628? i have a pic that, acidentally, had its code protection bits activated, and now i want to know if it is lost, or if there is another way to recover it. I do not care about the code that is already burned in it. i know that some pics have this function about erasing all the pic, chip erase, but i am afraid that this model does not have this function.
    Anybody can help?
  2. #2
    Full Member level 3
    Points: 3,020, Level: 12
    Join Date
    Mar 2005
    Morocco
    Posts
    182
    Points
    3,020
    Level
    12
    pic 16f628a cp
    Hello
    This is is Flash , you can Erase it Normally!
    Regards
    Cortex
    •   Alt10th March 2007, 00:01
      advertising
  3. #3
    Achievements:
    7 years registered
    mago's Avatar
    Join Date
    Jan 2006
    Posts
    23
    Points
    1,863
    Level
    10
    pic 16f876 erase code protection
    but when the code protection bits are enable, you don´t have access to the segment code you have protected, program and/or data code.
    and even trying to reprogram the flash, you cannot rewrite those bits in the configuration word.
    Am i wrong?
    •   Alt11th March 2007, 16:34
      advertising
  4. #4
    Advanced Member level 5
    Points: 14,575, Level: 29
    blueroomelectronics's Avatar
    Join Date
    Sep 2006
    Toronto, Canada
    Posts
    1,686
    Points
    14,575
    Level
    29
    code protect pic16f628
    Erasing a code protected PIC will erase everything. Just like a new PIC.
  5. #5
    Achievements:
    7 years registered
    mago's Avatar
    Join Date
    Jan 2006
    Posts
    23
    Points
    1,863
    Level
    10
    how to write data in eeprom of pic16f628a
    yes , that is what i want but how can i do that for pic16f628?
    is there any command in the porgram specification for doing this?
    •   Alt11th March 2007, 21:29
      advertising
  6. #6
    Full Member level 3
    folks's Avatar
    Join Date
    Oct 2006
    Guadalajara
    Posts
    182
    Points
    3,020
    Level
    12
    pic16f628a erase
    Quote Originally Posted by mago
    Mago, this is simple:
    1.- Open you software for pic Program (winpic800, icprog, Mplab etc...)
    2.- Erase the Pic
    3.- Your pic is ready
  7. #7
    Advanced Member level 1
    Points: 3,923, Level: 14
    Join Date
    Aug 2005
    Macedonia
    Posts
    440
    Points
    3,923
    Level
    14
    pic16f628 code protection
    Hi MAGO,
    this a simple view on ICPROG software, look option erase all,
    regards
  8. #8
    Achievements:
    7 years registered
    mago's Avatar
    Join Date
    Jan 2006
    Posts
    23
    Points
    1,863
    Level
    10
    thank you all, but i was wondering if that will work on a pic that had its code protected bits already set.
  9. #9
    Full Member level 3
    folks's Avatar
    Join Date
    Oct 2006
    Guadalajara
    Posts
    182
    Points
    3,020
    Level
    12
    pic16f628a program
    Yes your pic have the reason, read this (Microchip Datasheet):
    PAGE 89
    When the device is code-protected, the CPU can
    continue to read and write the data EEPROM memory. A
    device programmer can no longer access this memory.
    PAGE 111
    Only a Bulk Erase function can set the CP
    and CPD bits by turning off the code
    protection. The entire data EEPROM and
    Flash program memory will be erased to
    turn the code protection off.
    So you can write a code to turn off cp and cpd
    Sorry, but is true.
    1 members found this post helpful.
    •   Alt11th March 2007, 22:27
      advertising
  10. #10
    Achievements:
    7 years registered
    mago's Avatar
    Join Date
    Jan 2006
    Posts
    23
    Points
    1,863
    Level
    10
    pic16f628a code protect off
    Thanks my friends, i have finally concluded that when you set a code protection bit, you protect the area of memory (program and/or data, depending wheter you set the appropriate bits in the configuration word), in such a way that, when you try to read the program memory or data memory, you receive 0x0000 or 0x00 respectively. This protect someone else from stealing your code. however, if you run the bulk erase program memory command, you erase both of areas(data and program) and reset the configuration word to 0x3FFF, so that you can program again the pic, but you cannot see the code that was previously burned.
    Someone told me that its possible to "hack" the pic (i think that has something to do with manipulating the power pins), and they can do reverse engineering, disabling those protection bits and then read the code.
    I have found that some models have a special function called chip erase, that do what i mentioned above, and because pic16f628, doesnt had this function i was wondering that this old model would not clear after the protected bits were set. This is what was confusing me. Thanks everybody for the help.
  11. #11
    Newbie level 1
    Points: 825, Level: 6
    Join Date
    Apr 2008
    Posts
    Points
    825
    Level
    pic16f628 erase
    I have the same problem with a PIC16F877A.
    How can I disable code protect?
    I can't download the attached file *.pdf.
    Thank you. :)
