Problem with connecting to Internet using GlobeSpanVirata PCI ADSL WAN on Linux
Deathlich
Newbie level 6
Hello all, I have GlobeSpanVirata PCI ADSL WAN, and i cannot connect to internet via linux ( I have fedora core 6), also i tried to search in the company site, also didnt find, anyone to help me
thnx in advance
Modem drivers
Well Linux never really supported 56k pci modems, and if this is a pci dsl modem I don't believe you'll find drivers for it :(
Re: Modem drivers
you sure about this? well i think ill buy a usb modem:cry:
Modem drivers
I used this site do get my 56k modem working **broken link removed** if there are eny dsl drivers you can find them there
Re: Modem drivers
Hello!
you can use standart linux modem driver as driver who you wont to use
Re: Modem drivers
156845 said:
Hello!
What are you saying ? I don't understand ?
The use of a pci modem means that the processing eg. coding and decoding is done by the processor. And that needs an extra kernell module or what is known as a linux driver. You can not use a generic driver on eny Linux system, and by the way how would you do it ? What you need is a specific driver developed by the chipset manifacturer and/or the hardware manufacturer :)
Re: Modem drivers
III said:
156845 said:
Hello!
III speaks the truth, anyway, globespan merged with Conexant.
i have found this link hope it will help:
file:///C:/Program%20Files/eMule/Incoming/Linux%20drivers%20for%20Conexant%20Chips%20-%20Modem%20chipset%20identification.htm
Re: Modem drivers
Hi, just a related post : did any one have any success under linux with the modem that is shipped with the ibm t30 thinkpad ? from the output of lspci I am enlightened that my modem is an "Intel Corporation 82801CA/CAM AC'97 Modem Controller (rev 02)"
I've tried a number of modem drivers from the linmodem side but none of them seem to work.
I'm running suse 10.1 with a 2.6.16.13-4-smp kernel.
The other question that I would like to ask is which external modem would you suggest if a notebook's internal modem does not work ?
Cheers
Re: Modem drivers
hello again, using modemscanner i got this
10b9:5459 10a5:5459 Modem: ALi Corporation SmartLink SmartPCI561 56K
i am not pro in these things, do i have to install drivers with the same number"PCI561" or any number works?, or could you give me a link to download such a driver, thnx all
Modem drivers
Go to h**p://linmodems.technion.ac.il/,
download the scipt scanmodem h**p://linmodems.technion.ac.il/packages/scanModem.gz
execute it and write down the information,
finaly go to
h**p://linmodems.technion.ac.il/packages/ and download the apropriate packages
    Deathlich
Re: Modem drivers
-Kernel Vesrion:-
2.6.18-1.2798.fc6
-gcc version:-
gcc version 4.1.1 20061011 (Red Hat 4.1.1-30)
-binutils version:-
GNU ld version 2.17.50.0.3-6 20060715
And I always got this erroe for each "make" command"
[root@********* linux-atm-2.4.0]# make
make all-recursive
make[1]: Entering directory `/home/bdair2002/linux-atm-2.4.0'
Making all in m4
make[2]: Entering directory `/home/bdair2002/linux-atm-2.4.0/m4'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/bdair2002/linux-atm-2.4.0/m4'
Making all in src
make[2]: Entering directory `/home/bdair2002/linux-atm-2.4.0/src'
Making all in include
make[3]: Entering directory `/home/bdair2002/linux-atm-2.4.0/src/include'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/bdair2002/linux-atm-2.4.0/src/include'
Making all in lib
make[3]: Entering directory `/home/bdair2002/linux-atm-2.4.0/src/lib'
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -g -O2 -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c sapequal.c
rm -f .libs/sapequal.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -g -O2 -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c sapequal.c -fPIC -DPIC -o .libs/sapequal.lo
In file included from sapequal.c:12:
../../src/include/atm.h:11:23: error: linux/atm.h: No such file or directory
../../src/include/atm.h:97:
warning: 'struct atm_qos' declared inside parameter list
../../src/include/atm.h:97: warning: its scope is only this definition or declaration, which is probably not what you want
../../src/include/atm.h:98:
../../src/include/atm.h:99:
../../src/include/atm.h:101: warning: 'struct atm_sap' declared inside parameter list
../../src/include/atm.h:102:
../../src/include/atm.h:103: warning: 'struct atm_sap' declared inside parameter list
sapequal.c: In function 'match_blli':
sapequal.c:68:
error: label at end of compound statement
sapequal.c:86:
sapequal.c: At top level:
sapequal.c:123: error: conflicting types for 'sap_equal'
error: previous declaration of 'sap_equal' was here
make[3]: *** [sapequal.lo]
Error 1
make[3]: Leaving directory `/home/bdair2002/linux-atm-2.4.0/src/lib'
make[2]:*** [all-recursive] Error 1
make[2]: Leaving directory `/home/bdair2002/linux-atm-2.4.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/bdair2002/linux-atm-2.4.0'
make: *** [all-recursive-am] Error 2
The same error I got for make install, some ppl told me to download
"ungrab_winmodem.tar" from **broken link removed**
still the same error. The problem is I cant dowload anything, or doing any "make" or "make install" command to any file, Can anyone help me plz.
thnx in advance
Modem drivers
What modem are U compileing ?
Version of the modem x.y.z and verson of the kernel it was writtern ageinst?
Eny way looka at these packages:
As you can notice from the name of the files the build of the modems depend on the version of gcc you have installed.
I remember I couldn't build eny nvidia driver with the 4 series of gcc even tho the kernel itsealf was build with 4 series of gcc ;)
Re: Modem drivers
my modem is PCI smartlink
I am using patrick installation help
https://patrick.spacesurfer.com/linux_conexant_pci_adsl.html
this is not the problem, i think the problem comes from kernel, when searching on Google, ppl saying you have to update your kernel by using these commands
cd /usr/include
mv linux linux.orig
ln -s /usr/src/linux-2.4.24/include/linux linux
or
mv /usr/include/linux/atm.h /usr/include/linux/atm.h.bak
cp include/linux/atm.h /usr/include/linux/atm.h
but never worked for me, actually i think i destroyed my kernel :p
Modem drivers
cd /usr/include
mv linux linux.orig
this is strange and unnessary this is for the 2.4 kernel version and as you sayd your kernel is "2.6.18-1.2798.fc6". Reread what you've found and if this makefile is simular to the one I had firs do:
$make check
and read all unsatisfied dependencies
