What is the difference btween planar inductor & RFID coi
Logan_
Junior Member level 3
planar inductor
I am interested about RFID coil tag design but I have some doubts about.
RFID coil tag is fundamentally an inductor or antenna?
What kind of care I must have in design and simulation?
If it is an antenna I must consider in simulation ground plane?
what kind of port must be used?
Thanks Advance
rfid inductor
Hi Logan,
I am not very expert in RFID. But I think it all depends to the frequency of operation. For example in 13.56MHz systems, the tag should be in the near field of the reader. So the principle of power transfer is based on inductive coupling. Thus it is better to say the coil tag is an inductor.
In the other hand, for very high frequency systems, for example at 2.5GHz, the tag will usually be in the far field of the reader, thus the principle of power transfer is based on radiation. So now you should consider the coil as an Antenna.
I hope that helps you.
planar inductor and phd and developed
Hi OpAmp!
Thanks for you attention!
I am interested about RFID coil with inductive coupling at 13.56Mhz and not backscattering.
I have already simulated some examples in sonnet and IE3D, so I need to understand more about inductive coupling.
Do you have any reference, article, paper?
thanks advance
planar inductor antenna
Hi Logan,
Here are some application notes and design guides which helped me a lot in understanding RFID systems:
I hope they help you too .
OpAmp
    Logan_
