Diff Amp with active load vs diff amp with linear resistors
suhas_shiv
Full Member level 2
Hi all,
What are the pros and cons of Diff Amp with active load when compared to diff amp with resistors?
More gain and less area with active loads are the ones that I know of.
Thanks
Re: Diff Amp with active load vs diff amp with linear resist
it is hard to fabricate resistor with tightly-controlled values
active load provide large impedance , and influence the output swing less than resistors.
One thing more is that the output will either be a single ended or differential output.
The gain between the two are manipulated by current(active load) and resistor(resistor load).
the gain of the amp is Gm Rout. if you use a resistor, for example a 100k one, the swing will be like nothing, but an active load can give you a fair swing with a high gain
In general, Diff Amp with active load is good for gain,
diff amp with linear resist is good for speed such
as pre-Amp.
There is another major difference..
Active loads in general are non-linear.
Non-linear loads convert common mode noise to differential mode noise,
whereas linear loads dont.
Regards Prashanth
For resistive loaded differential amplfiers, gain will be gm*Rl, which requires high values of Rl to achieve moderate gain .However, these resistors will consume a voltage drop of Rl*Io/2 which would lead to a very limited headroom and would drive your transistors quickly out of saturation ,besides they consume lots of chip area .
So, for higher gains ,using active loads is more convenient .For active loads implementation, you can either use current sources at loads (MOS transistors each with a constant Vgs and none is diode connected) and in this case you'll need to have a CMFB network (Common Mode Feedback network) which is not easy to design .Or, you can use a current mirror at the load (single ended or unbalanced amplifier) and in this case your o/p will be single ended and more sensitive to Common Mode variation even in the case of perfect matching .
