+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Points: 12,823, Level: 27
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,823
    Level
    27
    proteus models
    hi here is new models
    3 digit cc and ca dispaly multiplexed
    3 didgit voltmeter chip TC7107(ICL7107)
    Thumb switch with commom pin bcd and hex
    regards
    Fragrance
  2. #2
    Newbie level 1
    Points: 729, Level: 5
    Join Date
    Nov 2008
    Posts
    Points
    729
    Level
    icl7107, proteus
    thank you fragrance a lot>>>
    i was searching for it
    thank you
    you are the best
    1 members found this post helpful.
    •   Alt10th November 2008, 16:39
      advertising
  3. #3
    Newbie level 1
    Points: 758, Level: 6
    Join Date
    Oct 2008
    Posts
    Points
    758
    Level
    new proteus
    Quote Originally Posted by Fragrance
    regards
    Fragrance
    hey do you have proteus model for DS12887 RTC?
  4. #4
    Newbie level 3
    Points: 1,155, Level: 7
    Join Date
    Apr 2010
    India
    Posts
    Points
    1,155
    Level
    7
    Re: New Proteus Models
    Hey i'm using proteus 7.4 sp3. I couldnt find DS1231 and LPC2388 in library. Can you please upload them...
    •   Alt19th April 2010, 08:04
      advertising
  5. #5
    Newbie level 2
    Points: 397, Level: 4
    Join Date
    Oct 2010
    Posts
    Points
    397
    Level
    Re: power electronics converter simulation in proteus
    i`m using proteus 7.7 and the tc7107 don't work; this say:
    PIN 'GND' not modelled
    PIN 'OSC1' not modelled
    PIN 'OSC2' not modelled
    PIN 'OSC3' not modelled
    •   Alt12th October 2010, 00:25
      advertising
  6. #6
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,823
    Level
    27
    Quote Originally Posted by younlink View Post
    hi
    these pin are not modeled any way or me it is working fine here is test jig for it
    2 members found this post helpful.
  7. #7
    Newbie level 5
    Points: 1,126, Level: 7
    Join Date
    Oct 2009
    PakistaN
    Posts
    8
    Points
    1,126
    Level
    7
    I also need this kindly any one give me this file TC7101 of 7.1 sp2 proteus or any link of proteus 7.7 plz urgent..thanks
  8. #8
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,823
    Level
    27
    Quote Originally Posted by asmarhussain View Post
    converted to isis 7 format
  9. #9
    Newbie level 6
    Points: 1,581, Level: 9
    Achievements:
    7 years registered
    Mohammad_Yhaya's Avatar
    Join Date
    May 2009
    Egypt
    Posts
    13
    Points
    1,581
    Level
    9
    dear Frinds .... i tried many times to apply the same circuit in the icl 7107 datasheet for range 200mV but it didnot work ,,,, i don't know why,,,,
    here you r my file ,,, please download it and find where is my fult ,,,, the datasheet circuit is Here.... many thanks
  10. #10
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,823
    Level
    27
    Quote Originally Posted by MOhamad_Yhaya View Post
    dear friend,
    you did just two mistake in your design corrected design file uploaded here and also share your working circuit image what you did wrong never adjusted the ref voltage also never short the -vin and Acom you never required batteries to give power to circuit as it is virtual simulator so you just required power net hope this will clear every point further you can check this schematic.Digital voltmeter using ICL7107 - Electronic Circuits and Diagram-Electronics Projects and Design
    regards
    Fragrance
  11. #11
    Newbie level 2
    Points: 379, Level: 4
    Join Date
    Aug 2011
    Posts
    Points
    379
    Level
    hi i gotta a question how can i connect ICL 7107 to an lcd not seven segment i mean i wanna use a lcd accept using 3 seven segment but the lcd is 16x2 and it has 7 internal ports but icl 7107 has 21 internal ports :(
  12. #12
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,823
    Level
    27
    Quote Originally Posted by galaxyboy View Post
    there is another version of the chip called ICL7106 which drive seven segment LCD display not 16x2 dot matrix LCD module
    regards
    Fragrance
    •   Alt8th August 2011, 07:39
      advertising
  13. #13
    Newbie level 2
    Points: 23, Level: 1
    Join Date
    Aug 2013
    Posts
    Points
    23
    Level
    hello guys,
    7 segments showing strange numbers,
    any idea whats wrong? using proteus 7.6
    best regards circuit
    Click image for larger version.
